PLP Robot --> Build Thread
Can anyone help me understand the HB-25 connection w/the BOE?
Does this look correct?
I can't tell anyone what "PLP" stands for - it's a secret, but Whit knows.
Scope
Post Edited (Scope) : 5/13/2010 1:27:31 AM GMT
Scope
Looks correct to me. You are running the HB-25 in mode 1 according to your drawing/pic - so the jumper on the HB-25 is in place - yes?
As far as the secret - anything·confessed to a priest must remain confidential.
Whit+
Wednesday, I'm going to request a project number for the 2010 RF Design Contest.
I believe when this project develops I may end up going with the Propeller however I'm going to get the ball rolling with the Stamp 2 (sorry the Stamp didn't show up in my image above - I was in a hurry).
Scope
No, not even close but very good guess.
I'll send you a PM
You don't need the red wire that goes from the BOE to the HB-25.
You probably already knew that...
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
I just figured you were using a standard three wire·servo connector - the red wire spot on the HB-25 is not connected to anything. It shows that in the documentation. W9GFO (Rich)·is correct - no wire is required, but a standard three wire connector can still be used and is probably easier. Likewise - the jumper on the BOE for·Vin or Vdd doesn't matter either, becase the red wire pin is not connected on the HB-25.
@erco - while your answer for meaning of PLP is true - it is not what Scope is referring to - Now - back to work you trouble maker!
Whit+
Post Edited (Whit) : 4/7/2010 7:48:15 PM GMT
My request for a project number has been completed & submitted.
I think I'm biting off more than I can eschew.
Or something like that.
Cheerios!
Excellent guesses . . . no, and no.
You install gutters and you’re going to use it to accurately feed down spouts to your cutoff saw in the exact length you tell it too by RF?
If not, it still looks intriguing.
Tony
No - another great guess
rpdb
Wandering around Home Depot I discovered a plastic gutter has a fairly impressive strength to weight ratio and I needed a 12' lightweight beam. Ya, the "box" will be traveling on the gutter . . . but why?
Clue: The gutter beam will be moving.
Post Edited (Phil Pilgrim (PhiPi)) : 5/14/2010 3:18:02 AM GMT
Think outside . . . as in parking lots & lawns.
It's going much slower than I'd anticipated. I'm planning on using the modified E-Maxx for the tractor. I plan on using RF, to control autonomous and semi-autonomous modes of operation.
Slow, frustrating at times, but overall, it's a very fun project.
Thanks for Whit not telling anyone (ha).
Prototype 02 will only employ one - if . . . er, when that is operational, we'll move to either dual trucks (?) &/or multiple media per truck.
I also thought of doing one with the Kansas Dot technique - boom swings around a post as media is disbursed. I was flying over Kansas and saw many of those dots. The x/y system seems to be simpler in most ways.
Currently, I'm using the nozzles and thin tube nozzle extensions from cans of WD-40 onto paint cans w/high torque servos serving as actuator mechanisms. It's a messy learning curve.
My primary goal is simply to develop a working model - from that, I'll begin developing and ironing out the many details/shortcomings.
I also haven't decided on Stamp vs. Propeller. I am not very good w/Spin Tool. Geeze, I'm not very good w/PBASIC either, now that I think about it.
What a great idea! My mind is a buzz with ideas an issues that will need to be solved. Looking forward to your progress.
You mention the "Kansas Dot Technique". Do you mean the device paints large circles/dots in yards? What are the dots for?
Tony
The "dots" are created by the farms that use rotating irrigation systems - I guess there's a better way to describe them but they look like dots from 32,000 feet.
For a circular scan, there's always this technique: hackaday.com/2010/04/26/lawnmowerstakeropeanalog-robotic-lawn-service/.
