Stingray compatability — Parallax Forums
DutchBotDutchBot Posts: 24
edited 2010-05-14 01:01 in Robotics
Hello all,
I finally managed to get my bot with the MRS1 roaming arround the house on 3 pings, nice! Time for some new tricks I guess, I already·received the Parallax Postion Controller kit (http://www.active-robots.com/products/parallax/position-controller-kit.shtml)·and would like some line following sensors also. I wondered if these parts are compatible with the robot control board in the first place? Seems the position controllers are but I'm not sure.
This is the line kit I would like:
QTI Line Follower AppKit
for the Boe-Bot ( http://www.active-robots.com/products/parallax/qti-line-follower-appkit.shtml·) Just says its for the boe-bot....
Thanks for any help!
Best regards,
Louis
    edited 2010-05-06 16:42
    Louis,
    FYI, encoders and line following sensor are in the works for the Stingray.
    Chris Savage
    Parallax Engineering
  • DutchBotDutchBot Posts: 24
    edited 2010-05-07 12:23
    Hi Chris,
    bummer but thanks for the info. I already bought and received the wheelencoders. Guess I have to buy a boe-bot to go with it now.
    Best regards,
    Louis
  • WhitWhit Posts: 4,194
    edited 2010-05-07 20:24
    Louis,
    I think what Chris means is that encoders and line following kits are planned specifically for the Stingray. That does not mean that what you have could not be used - it just might be more difficult - for example coming up with a wat to mount the boards and adding a notched wheel for the senors to read. What you have is not uncompatable with the Propeller Robot Control Board.
    Likewise the line following kit could be adapted as well.
    Whit+
    edited 2010-05-10 06:32
    Thanks Whit, thats great news! I just use the MRS1 and not the actual stingray platform.
    819 x 847 - 235K
  • rpdbrpdb Posts: 101
    Louis,
    I have a QTI line following kit I'm not going to use if your interested?
    rpdb
