PCB milling machines - JCUT-3030 PCB - any good?
Peter Jakacki
I want to be able to churn out simple pcbs to mount my PUPPY modules on etc and I have been looking at some cheap PCB milling machines that mill away the copper around a track and also drill the pcbs. Has anyone had any experience with these cheaper machines?
jcut2.ec51.com/sell-show-pcb_cnc_router-281942.html
*Peter*
*Peter*
Specs: www.cnc-laser-cutter.com/PCBcncrouter.html
Drilling: www.youtube.com/watch?v=WF8DPSS9JnE
Milling: www.youtube.com/watch?v=_KZqqSEMITo&feature=related
*Peter*
Better yet, order new boards, buy a used benchtop, and even still have money left to rig up a home brew pick n place like I did here:
www.youtube.com/watch?v=jW0z5Hct3xU
[noparse]:)[/noparse]
Post Edited (Todd Chapman) : 5/6/2010 4:49:25 PM GMT
I did look at the Taig MicroMill CR, how would that be for milling pcbs? Would you just rely on G-code or a gerber? The machine looks powerful and precise enough for a lot of jobs, even routing out plastic and metal enclosures.
*Peter*
One point about getting a decent CNC is that you can do so many other things with it. I have machined stainless, steel, alum, delrin, polycarb, and glass all on a $2500 benchtop very similar to the taig benchtop. The machine also doubles as pick and place weekly for production. I order panelized 12 x 14 boards from Sunstone, and route the individual boards on the CNC, which is very convenient. Many people will have derog comments but I really like Bobcad for generating code for machining, and mach3 is great for running the code, good low cost combo compared to the big boys.
You have a good argument about prototyping, but keep in mind there IS a hassle factor with routing PCBs that you have to weigh in when calculating protos though (you know better than me, just a reminder [noparse]:)[/noparse] ) After many hundreds or even thousands of hours on this path of making and assembling boards, I do not believe there is any benefit to routing boards at home even for protos. At least with the benchtop CNC, and then you get long term value out of the machine. Routing PCBs can take time on a machine, I always opted for etching with chemicals over routing, then drilling with the Gcode.
Post Edited (Todd Chapman) : 5/7/2010 6:44:33 AM GMT
groups.yahoo.com/group/taigtools/
I think that some people there have used them for making PCBs. I use photo etch at home and can make a PCB in under 30 minutes, with 8 mil tracks. I don't see the point of buying an expensive machine to make them.
Leon Heller
Amateur radio callsign: G1HSM
Why would you want to take the time to mill a board when you can print a couple transparencies, throw them under a light, develop and etch them? It's easier, faster, and you can get "finer" results (trace width, spacing, etc.).
The most expensive part of the whole thing is the lights, and you don't "need" to have UV lights, it just makes exposre faster. Heck, when I was a "kid", I use the sun to expose boards made with hand inked "masters" (circa 1970 ish).
John R.
Click here to see my Nomad Build Log
I even supply home-made prototypes to clients, sometimes. One of them is still using my boards in a high-power ultrasonic system I designed for him about six years ago.
Leon Heller
Post Edited (Leon) : 5/7/2010 3:35:51 PM GMT
*Peter*
Leon Heller
Post Edited (Leon) : 5/7/2010 4:30:39 PM GMT
Post Edited (Todd Chapman) : 5/7/2010 4:39:21 PM GMT
It is well into the sixes, but they have less costly models, if I recall correctly in the $20K range.
Occasionally they pop up on ebay.
Cheers,
Peter
