Wireless boe bot controlled by pc?
I have a boe bot and two parallax 433Mhz transceivers i am trying to controll the boe bot·with my pc through the serial port. I have a max232 but i cant see to figure it out and this is my last hope. I was wondering if there was any thing special that i needed to do to get them to communicate?
- Stephen
' Tcvr_TxCode_v1.1.bs2
'{$STAMP BS2}
'{$PBASIC 2.5}
x VAR Word
y VAR Word
HIGH 1 ' T/R Line
DO
PULSOUT 0, 1200 'Sync pulse for the receiver
SEROUT 0, 16468, [noparse][[/noparse] "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
x = x + 1
y = y + 1
PAUSE 10
LOOP
and its says it needs two stamps (one on the recieve end and the transmit end)but i am pretty sure it can be done with only one stamp?
- Stephen
You might want to consider "RobotBasic" which will allow you to communicate with your bot from your PC.
TCIII
If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
