Wireless boe bot controlled by pc? — Parallax Forums
EastBurkeEastBurke Posts: 17
edited 2010-05-14 04:27 in Robotics
I have a boe bot and two parallax 433Mhz transceivers i am trying to controll the boe bot·with my pc through the serial port. I have a max232 but i cant see to figure it out and this is my last hope. I was wondering if there was any thing special that i needed to do to get them to communicate?
    edited 2010-05-07 02:26
    What have you tried and how do you have them connected? ATTACH your code to a post using the attachment manager so we can have a look.
    - Stephen
  • EastBurkeEastBurke Posts: 17
    edited 2010-05-07 02:34
    Well i started with the sample code
    ' Tcvr_TxCode_v1.1.bs2
    '{$STAMP BS2}
    '{$PBASIC 2.5}
    x VAR Word
    y VAR Word
    HIGH 1 ' T/R Line
    DO
    PULSOUT 0, 1200 'Sync pulse for the receiver
    SEROUT 0, 16468, [noparse][[/noparse] "!", x.HIGHBYTE, x.LOWBYTE, y.HIGHBYTE, y.LOWBYTE ]
    x = x + 1
    y = y + 1
    PAUSE 10
    LOOP
    and its says it needs two stamps (one on the recieve end and the transmit end)but i am pretty sure it can be done with only one stamp?
    edited 2010-05-07 02:36
    and i have to tansciever on the computer end connected to the max232 which is connected to the 9-pin serial connecter
    edited 2010-05-07 02:38
    Since the code you posted is for the transmitter just connect the other radio to your computer and use a terminal progran to receive the transmitted code.
    - Stephen
    edited 2010-05-07 02:42
    I want to transmit with the pc end and recieve with boe bot end. what do u mean "terminal program"?
  • Tom CTom C Posts: 461
    edited 2010-05-12 16:24
    EastBurke,
    You might want to consider "RobotBasic" which will allow you to communicate with your bot from your PC.
    TCIII
    If you are going to send·a Robot·to save the world, you·better make sure it likes it the way it is!
    edited 2010-05-12 16:57
    I am not familiar with that, but i can give it a try
    so do i send the data through the DEBUG terminal? or is there a special program to use?
