Stingray Work/Test Stand — Parallax Forums
Tony B.Tony B. Posts: 356
edited 2010-05-06 20:33 in Robotics
Here is the promised work/test stand for the Stingray. I have attached an Instructions and Plans PDF and some pictures of the completed project. I have kept it as simple as I can, but think it is better that using a cardboard box.
Please post any questions you may have.
I hope Whit will think it good enough to add to the Stingray Resources Forum located here http://forums.parallax.com/forums/default.aspx?f=10&m=442984
Hope this helps with your work on the Stingray.
Tony
Post Edited (Tony B.) : 5/4/2010 1:03:30 PM GMT
  • WhitWhit Posts: 4,191
    edited 2010-05-04 17:00
    Looks great Tony. I love the use of the Prop Beanie sticker too...
    Whit+
  • allanlane5allanlane5 Posts: 3,815
    edited 2010-05-04 18:00
    Excellent. That's one of the first things you find you need, once you have your robot working. Otherwise, it tends to skittle off everywhere.
    edited 2010-05-05 17:07
    Very nice...and here I was using a small carboard box. =/
    Chris Savage
    Parallax Engineering
  • Tony B.Tony B. Posts: 356
    edited 2010-05-06 02:07
    Thanks for the comments all.·
    When I started with the BOE-BOT I nearly lost it off the table because I was focusing hard to get the movement code right.· Forgetting that it was setting on the wheels, I downloaded the code and it took off.· I just verily saved it.· That's why I use work/test stands.
    Tony
    edited 2010-05-06 12:13
    I think every person building a wheeled robot has done this once or twice. It's REALLY not obvious when you begin that this can happen, but once you program it for motion and it dives off the table, the "Of COURSE I need a test stand!" idea comes to everyone.
  • ScribblerKartScribblerKart Posts: 45
    ScribblerKart
    Uh oh, ScribblerKart time!
