Update Project from SD Card — Parallax Forums
JonnyMacJonnyMac Posts: 9,819
edited 2010-05-10 22:32 in Propeller 1
I'm sure others have tried this and I hope those that have will offer suggestions and their experience with "gotchas."· While talking with a potential customer last week he asked if we could update the data for the project from the SD card that was already there; "Sure, no problem.· In fact, " I continued, "we could even update the proudct, too."
Well, I thought I should actually test my theory and it turned out to be sound.· Mind you, this is a butt-simple experiement but it was done to prove a point (mostly to myself).· The attached program (setup for a Demo Board) has a method called checkupdate that, 1) attempts to mount the SD card, 2) looks for a file called "update.pgm", 3) checks to see if the file is 32K.· If all that is true then it moves it, 64 bytes at a time, to the boot EEPROM and reboots the Propeller.
In the end, my goal is to allow SD enabled products to be easy to update, even for my tech-nervous customers.· I created two EEPROM images with different LED patterns and have happily gone back and forth between them by copying the desired image to "update.pgm."
Jon McPhalen
Hollywood, CA
    edited 2010-05-05 04:40
    It's better to use a 64K byte EEPROM if possible. That way, you can have a loader/updater permanently in the first 32K that attempts to mount an SD card. If that succeeds, it attempts to open a specific file and copy it to the 2nd 32K of the EEPROM. Once that completes, it goes to the same code that's executed if either the copy, open, or mount fails which checksums the 2nd 32K then loads and executes it if the checksum is valid.
    Alternatively, you could build this whole logic into your program, but copy the 2nd 32K to the 1st 32K if the copy to the 2nd 32K succeeds.
    The advantage with this scheme is that the copy from the SD card will not overwrite the 1st 32K in the first case or will only overwrite the 1st 32K if everything checks out. A failure during the SD card I/O will not "brick" the system.
  • Nick McClickNick McClick Posts: 1,003
    edited 2010-05-05 04:55
    I wanted to build something like this for the Propeller Platform SD (that's why I put a 64k eeprom on it), but haven't had the chance to.
    I was originally thinking that based on the filename, it would either re-write the lower 32k, write to the upper 32k, or load directly from the card. If nothing was found, it would load the upper 32k.
    Propeller Forums RSS Feed!
    Gadget Gangster - Share your Electronic Projects
    edited 2010-05-05 05:09
    mctrivia has an object for this in the OBEX. It flashes the upper 32KB for failsafe operation.
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-05-05 09:02
    I've had an hardware approach for a while on my breadboard setup. I simply had 2 EEPROMs and connected the address-pins to a switch. So you can choose with the switch which one to use for boot. The advantage is that you don't have to boot a bootloader which then boots the real program. And you can still use the propeller-tool during development to update whatever EEPROM you want to update directly.
    The extra costs are not to much and you can even put one EEPROM on top of the other in case you don't have the PCB estate.
  • Brian RileyBrian Riley Posts: 626
    edited 2010-05-06 20:23
    Cluso99 said...
    Have you got some more info on how to find this object?
    The OBEX is a great concept, but trying to find things there is like pulling teeth!
    It took another 20 mins but I eventually found it ....
    obex.parallax.com/objects/473/
    Nick, this is exactly what you are looking for, at least according to the writeup on the OBEX.
    cheers ... BBR
    cheers ... brian riley, n1bq, underhill center, vermont
    The Shoppe at Wulfden
    www.wulfden.org/TheShoppe/
    www.wulfden.org/TheShoppe/prop/ - Propeller Products
    www.wulfden.org/TheShoppe/k107/ - Serial LCD Display Gear
    Post Edited (Brian Riley) : 5/6/2010 8:36:38 PM GMT
    edited 2010-05-07 04:31
    OK,
    I downloaded three fresh copies of three SD based loaders
    1 - jonnymac's - loads in EEPROM, runs and replaces itself with a program update from SD card. I am not sure what the point is (no offense jon), since te UPDATE.PGM overwrites the re-loader code in low EEPROM. But the code is very clean and all aspects work as advertised, right down to erasing the update file at the end. The i2c and spi code is fresh and clean.
    2 - Nick's barebones loader with stays in low EEPROM, looks for and loads a file called RUN.BIN to RAM and it runs.
    3 - Matthew Cornelisse's Bootloader 1.01 (OBEX #473), which does load a file called CODE.BIN to high EEPROM from SD, but then fails to erase the file and fails to execute the program in high EEPROM, remove the sd card and punch reset and it loads and runs the program in High EEPROM.
    Very confusing ... Matt and Nicks code are similar but contain, as far as I can see subtly different versions of mike green's FEMTO code for I2C/SPI/SD. Jon's code is lots newer seemingly with advantages of all that time since Mike's work to get it all right. I particularly like Jon's approach to I2C because he explicitly passes the EEPROM ID ($A0) and start address ($0000 or $8000). If I use an SD add-on card with my Prop Platform, I could load the second EEPROM (ID is $A2) and have my choice. Mike's code buries the $A0 down deep but, alas, Jon's code doesn't have the bootEEPROM and bootSDcard routines that Mike's has.
    Post Edited (Brian Riley) : 5/7/2010 4:37:12 AM GMT
  • JonnyMacJonnyMac Posts: 9,819
    edited 2010-05-07 14:44
    As I pointed out, this was an experiment; I'm working on a product that has an SD card and I wanted to make it EXCEEDINGLY EASY for my non-technical customers to install a future program update (i.e., without having to using the Propeller Tool). I realize my scheme has limits (all schemes do), but it does work. Any new version of the product code that installs would, of course, also have the checkupdate method so that it could be updated again as customers ask for new features.
    Unlike many others, I do not default to the ObEx; I tend to enjoy the experience of doing something for myself and writing code. It's tragic that some (not you, Brian) take the attitude, "It's already been done, why did you bother?" Why? Mount Everest has been climbed many times but others continue to do it for the challenge and the experience. Programming is fun; I like doing it -- even if the code I'm writing is not particularly unique. If it's new to me then that is good enough and I'm sure I'm better off in the end. If others are helped by my efforts, great; if not, no harm was done by me (or others) sharing.
    The Propeller, and ObEx in particular, tragically, has encouraged a new level of laziness among some (mostly young and new) programmers who's default position is, "Where is the object to do this?..." (This is not unique to programmers; PJMonty told me yesterday it happens in the visual effects business all the time with new artists asking "Where's the plug-in?"). Even where objects exist I tend to go my own way when said target is within (or just beyond) my present comfort zone and abilities -- again, I enjoy the opportunity to learn.
    I, for one, think objects should be small (as small as possible), discrete, specific, and flexible; hence my I2C object just provides I2C communications routines, but doesn't limit them to a single device address.
    Jon McPhalen
    Hollywood, CA
    Post Edited (JonnyMac) : 5/7/2010 2:59:16 PM GMT
    edited 2010-05-07 14:49
    @Jon,
    Slick application! It will save me from "recreating the wheel" in my current project, allowing me to spend my limited
    propeller time creating other neat ideas and code. [noparse];)[/noparse]
    OBC
    Are you Propeller Powered? PropellerPowered.com
    Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
    edited 2010-05-07 15:00
    @OBC,
    Thanks! Now... per my rant (grin) above, I think it's quite okay -- when one does have the time -- to reinvent wheels; this process often leads to better wheels (note to others: I'm not suggesting the above code is better than what other have done, it's just another offering).
    Jon McPhalen
    Hollywood, CA
    edited 2010-05-07 15:41
    JonnyMac said...
    D'oh! Boy did I miss that ..... I retract my don't see it with a few mea culpas ... makes perfect sense now
    JonnyMac said...
    As I pointed out, this was an experiment; ... I realize my scheme has limits (all schemes do), but it does work.
    No apologies or qualifiers needed ... it works perfectly and the code is crafted nicely that it could be extended.
    cheers ... BBR
  • MacTuxLinMacTuxLin Posts: 821
    edited 2010-05-08 23:42
    Hey Jonny,
    This obj is cool (tried it) & easy for a rookie like me to understand. And, exactly what I was looking for (end-user update of new code)!
    Thanks.
    edited 2010-05-09 03:01
    Well I started with Obex #473 and massaged it and got it working. Thenn added ideas from Jon, Nick, etc One thing kept tripping me up, the write to EEPROM routines take 15-30 seconds and I kept aborting things to soon thinking it was hung.
    It works like this, in this priority order,
    1 - inserting an SD/uSD card and assuming a 64K EEPROM - *
    2 - looks for a file called RUN.PGM, if found it loads to RAM from SD card and runs - ***
    3 - looks for a file called UPDATE.LDR, if found it loads from SD card into low EEPROM (lower 32K), then erases UPDATE.LDR from SD card - **
    4 - looks for a file called UPDATE.PGM, if found it loads from SD card into high EEPROM (upper 32K), then erases UPDATE.PGM from SD card - **
    5 - loads high EEPROM to RAM and runs
    * - no SD card present - skips to step 5
    ** - if a file named NODELETE.TXT is on the SD card, the deletes do not get made
    *** - this code doesn't work right yet, see below
     if sd.popen(@RunNow, "r") == 0
        sdspi.bootSDCard(sd.get_datablock, sd.get_filesize <# $8000)
    This code hangs in bootSDCard not sure why!
    I added the two sd.get_ routines as PUBs in fsrw.spin to get at the private data. This code works in Nick's routine.
    MMMMiiiiikkkeeeee!!!!!! Help! Please!
    cheeers ... BBR
    edited 2010-05-09 03:32
    The problem you're running into is that you have two cogs both trying to access the same I/O pins. bootEEPROM tries to access I/O pins 30/31 using a separate cog and your use of Basic_I2C_Driver leaves the main cog also with I/O pins 30/31 in use. bootEEPROM eventually stops all the other cogs except the one with the boot loader in it, but first it tests for the presence of an EEPROM at the specified address and this test probably fails.
    Using bootSDCard runs into the same problem, but it's more involved. sdspiFemto and sdspiqasm both start up a separate cog and both cogs will try to access the SD card using the same I/O pins. You have to stop sdspiqasm before calling bootSDCard, then you have to call initSDCard and provide the pin numbers for the SD card.
    You might be better off using fsrwFemto along with sdspiFemto instead of using fsrw and sdspiqasm. You could even use the read / write routines for EEPROM that are part of sdspiFemto instead of the Basic_I2C_Driver routines. They're faster.
    You might look at FemtoBasic since that includes routines that do much of what you want. In particular, the COPY statement can be used to copy a binary program from an SD card file to a 32K block of EEPROM. You might look at that routine in FemtoBasic.spin, lines 1087 through 1111.
    You might also look at the SPIN statement in FemtoBasic.spin, lines 1068 through 1078. This executes a program either in an SD card file or a 32K block of EEPROM.
    Post Edited (Mike Green) : 5/9/2010 3:41:09 AM GMT
    edited 2010-05-09 03:57
    Mike Green said...
    But bootEEPROM works just fine in that code . I also do not understand why they would be going after 30/31 the eEPROM is on 28/29
    Mike Green said...
    Here is my problem. There's a number of minor variations and NOWHERE is there a roadmap! I used what I had because my baseline code was Matt's Obex #473 and that is what he used. But I was implementing ideas from Nick (he used your suggested scheme) and Jon (he used fsrw 2.6 and some other new code ... besides Jon cheated wink.gif, he wrote to low EEPROM and then used a spin reset command and let the Prop bootloader do the heavy lifting.)
    Could you take a few words and differentiate the various pathes through the I2C/SPI/SD/EEPROM minefields.
    edited 2010-05-09 04:17
    Sorry, I should have said 28/29.
    Attach is a recoded version of your loader using fsrwFemto and sdspiFemto and the routine from the COPY statement. It compiles, but I haven't tested it yet.
    edited 2010-05-09 04:19
    Mike Green said...
    Thanks Mike, those two paragraphs have given me enough info to approach restructuring my code to use fsrwFemto and sdspiFemto with some confidence.
    I would still be interested in a short tutorial on what is which in the fsrw/sdspi/i2c world.
    cheers ... BBR
    edited 2010-05-09 04:32
    Let's see what's what ...
    First came the I2C routines in the Propeller OS years ago. This was a PASM I2C driver that included an I2C boot loader.
    This was extended to include low level SD card SPI routines including an SD card file loader and became sdspiFemto. I modified Rokicki's FSRW routines to work with it and these became fsrwFemto.
    Rokicki did some experimenting with faster low level SD card SPI routines which are included with the 1.4 version of FSRW (for FAT16 only). This is sdspiqasm. They're somewhat faster than sdspiFemto, but can't load a file and they don't have the I2C routines.
    There's now a 2.6 version of FSRW that can handle FAT32 formatted SD cards. It could be modified to use sdspiFemto, but I haven't done that yet. There are other SD card I/O drivers as well, one by Kye that's still under development that will include FAT32 support, subdirectories, and an SD card file loader. There's another one that's part of Sphinx that's completely in PASM.
    Basic_I2C_Driver is a Spin-only I2C driver, mostly for reading and writing to EEPROMs. It has no EEPROM loader.
    James Burrows also developed a Spin-only I2C Driver which included support for specific non-EEPROM devices. He originally had his own low level I2C driver, but later used the routines from Basic_I2C_Driver. Similarly, the BS2_Functions package now uses the low level I2C routines from Basic_I2C_Driver.
    Post Edited (Mike Green) : 5/9/2010 3:14:54 PM GMT
    edited 2010-05-09 04:52
    Mike ... THANK YOU for this ... it should be printed up in 40 point type with phosphorescent ink and nailed to the front door of this joint!
    Thanks also for the code work. It looks more or less like what I envisioned when I looked at the references you gave me. I will test it tomorrow when I am awake enough not to make stupid mistakes.
    Quick question (probably requiring not so quick answer) Why are some method calls prefixed with "\" and others not yet all have "abort' specifications?
    Second quick question, the texts in the abort specifications where do they get dumped ... to a P30/P31 to a serial terminal?
    cheers ... BBR
    Mike Green said...
    Rokicki did some experimenting with faster low level SD card SPI routines which are included with the 2.4 version of FSRW (for FAT16 only). This is sdspiqasm. They're somewhat faster than sdspiFemto, but can't load a file and they don't have the I2C routines.
    edited 2010-05-09 15:04
    1) The "\" is to catch the abort. If you prefix a call to a method with "\" and it executes an ABORT, the abort stops there (as it unwinds the call stack) and the method with the "\" in front of it returns the value passed to the ABORT.
    2) I copied and modified the code in FemtoBasic. The ABORT STRING "... stuff ..." causes the address of the string to be passed back where it's used as part of an error message to the user. fsrwFemto also uses this for one or two of its errors.
    edited 2010-05-09 18:54
    Its all done and running nicely. Mike overlooked an ' sd.start(ioControl) ' which caused nothing to work. I figured Mike's work couldn't be that far wrong and it had to be something simple ... I looked over Nick's simple loader, which uses the femto code as well and found the start invocation and, voila. It all worked perfect.
    I am going to start a new thread with the source code etc.
    http://forums.parallax.com/showthread.php?p=905248
    cheers BBR
    Post Edited (Brian Riley) : 5/9/2010 7:58:18 PM GMT
    edited 2010-05-09 19:00
    Sorry about that Brian. Mike
    edited 2010-05-10 08:14
    Hi,
    I'm looking at the portion on writing to the eeprom:
    check := i2c.putpagex($A0, addr, PG_SIZE, @buf)
    if (check == i2c#NAK)
    term.str(string(" -- EE write error", CR))
    quit
    If there is really a problem while writing half-way, will it cause the eeprom to be unuseable/unbootable?
    edited 2010-05-10 13:53
    @Ruddy,
    Yes, it could, unless the write failure happens past the actual working portion of the code. Remember, this was a test program, not meant for actual deployment as-is. In my case I have a bi-color LED that keeps the user informed (flashing yellow = programming, solid green = success, red = failure). I've run that program many times now without problems and I don't expect to have them in field -- I just tend to be a conservative programming (well, mostly) and attempt to trap possible error conditions.
    Jon McPhalen
    Hollywood, CA
  • KPRKPR Posts: 189
    edited 2010-05-10 14:09
    JonnyMac..
    Did you add the LED for the status, because that sounds really handy..
    I always have someone watching my back.
    edited 2010-05-10 15:21
    I already had it on the product. We (EFX-TEK) started using a bi-color LED for status information in an SX-based product and it was a big hit. With the Propeller, I have a bi-color LED object that lets me easily change color, and even flash between two colors (you can find it in ObEx, and I describe it in one of my Nuts & Volts columns).
    Jon McPhalen
    Hollywood, CA
    edited 2010-05-10 15:45
    @Jonny
    Thank you. Yes, I'm thinking along that line as well. I've tried your code a number of times, no problem. For the current project I'm working on, I'll probably need to add in some tolerance as power failure could be a norm in the field where they are going to be deployed. I have battery added but just wanted to be extra safe. So, I'm thinking of adding a separate eeprom for running the active project (prone to changes) & the main eeprom for running the checkupdate plus other comm from senors & update back to server but I don't know how to launch code in another eeprom. Sorry if this had been answered before but if you could direct me where to look, it be appreciated.
    Thanks.
    I really can't think of a practical scheme involving two EEPROMs, or even one 64K EEPROM. There have been ideas presented in this thread, but don't work for me (philosophically, that is). Yes, there is always the possibility of "bricking" the system; about the only way to completely avoid that is to treat the project like a game: power down and insert a new cartridge (boot EEPROM). For a situation like yours when this might in fact be a clean solution (and requires no additional code!).
    Jon McPhalen
    Hollywood, CA
