Stingray Work/Test Stand
Here is the promised work/test stand for the Stingray. I have attached an Instructions and Plans PDF and some pictures of the completed project. I have kept it as simple as I can, but think it is better that using a cardboard box.
Please post any questions you may have.
I hope Whit will think it good enough to add to the Stingray Resources Forum located here http://forums.parallax.com/forums/default.aspx?f=10&m=442984
Hope this helps with your work on the Stingray.
Tony
Post Edited (Tony B.) : 5/4/2010 1:03:30 PM GMT
Tony
Whit+
Chris Savage
Parallax Engineering
When I started with the BOE-BOT I nearly lost it off the table because I was focusing hard to get the movement code right.· Forgetting that it was setting on the wheels, I downloaded the code and it took off.· I just verily saved it.· That's why I use work/test stands.
Tony
ScribblerKart
Uh oh, ScribblerKart time!
