Surface mount prop board
Hello,
I wanted to try my luck at making my project with smt components. I have attached an image of my prop pcb. Please critique my work. Have I missed anything? Thanks for your comments. The pcb circuit was done in ExpressPcb.
Curtis
Curtis
Leon Heller
Amateur radio callsign: G1HSM
I would also add a couple of tantalum capacitors (10 to 47uF), one on
each side of the voltage regulator.
Russ
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
I could suggest you not to use right angles in traces, instead use ie: 45deg angles.
Regards.
Alberto.
I messed up that RST header. I'll fix it. I am using headers so when I put it in an enclosure, It will be available.
Thanks everyone, I'll fix the problems and repost it.
Curtis
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
Post Edited (yarisboy) : 5/4/2010 7:53:05 PM GMT
There is one thing I would change if you haven't made the boards yet. It looks like there is unused area on the board and you're not connecting a large portion of the I/O. Since you have the space why not add some more pads and wire them up to the extra I/O so you can use them if you need them later?
Robert
Are you going to·be programming the eeprom·before putting it in circuit?
You may want to wire in a connector for a prop-plug. That will at least give you an option to upload code later (may make it a bit more useful).
