Removing the Retaining Rings from Parallax 7.2V Motor Wheels?
I'm getting very frustrated - I have no idea how to get these off
The instructions indicate:
Do I have to purchase a set of snap ring pliers or is there a safe, alternative method to get them removed?
Post Edited (Scope) : 5/1/2010 8:37:40 PM GMT
Parallax instructions said...
Install a wheel onto each hub. While wearing safety glasses, use snap ring pliers to install a retaining ring around the groove in the outer part of each hub.
I also picked up a stripper
But please don't tell my wife
Where did you find the Channel Lock set?
Whit+
I got both of these tools at Home Depot
The wire strippers will come in very handy this week as our class is building Propeller kits from Brian Riley. I also obtained wire for our school project yesterday from Radio Shack. Now, if the IT dept would just install Spin tool - I'm not allowed to touch the computers in my classroom.
Phil, I could use a system like that in my storage shed - after renaming it, of course.
@Phil - I wouldn't get the chance to "splain" - I'd be hanging on it.
Whit+
Chris Savage
Parallax Engineering
Chris Savage
I've also seen them in the clearence bin at Ace Hardware.
You better off using the right tool or you will be looking for the snap ring when it flies off.
Don't try and use a finger in place of a dowel or rod. It hurts like heck, and could do some real harm under the right circumstances.
Snap ring pliers work wonders, in that you are "squeezing" the pliers to open the ring, not trying to spread the handles of a needle nose pliers.
They also make the "inside out" version for internal snap rings.
Some of the snap ring pliers kits use replaceable pins that are clamped in place. Some of these clamping mechanisms are better than others. Just something to watch for.
And remember, of all the organs you would miss, the eyeballs are probly at the top of the list. (Yes, even higher on the list than "the boys".)
John R.
Click here to see my Nomad Build Log
John R.
