A PBasic routine How would you write it to do the same thing in Spin
Here is the routine
Thanks to anyone that can help
·Now wanting to learn Spin· Thanks for any·
·that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 4/27/2010 2:03:36 PM GMT
' {$STAMP BS2}
' {$PBASIC 2.5}
chg VAR IN0
cntr VAR Byte
' The table is [color=red]IF Chg = 1 Then Loop = 100[/color] [color=blue]If Chg = 0 THEN Loops = 0 [/color]
DO
cntr = cntr + 1 * Chg
IF (cntr = 100) THEN EXIT ' Exit or to a subroutine
LOOP
Sam
repeat cntr := cntr + ina[noparse][[/noparse] 0 ] if cntr == 100 exit▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Sam
input_pin = 3
var
long ctr
Pub main
dira[noparse][[/noparse]input_pin]~
repeat until ctr == 100
ctr += ina[noparse][[/noparse]input_pin]
John Abshier
I want to Thank John Abshier for his help
Sam
repeat ctr := ++ctr * ina[noparse][[/noparse]Chg] if (ctr == 100) exit▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Jon McPhalen
Hollywood, CA
' {$STAMP BS2} ' {$PBASIC 2.5} chg VAR IN0 cntr VAR Byte ' The table is [color=red]IF Chg = 0 Then Loop = 100[/color] [color=blue]If Chg = 1 THEN Loops = 0 [/color] DO cntr = cntr + 1 * (1 - Chg) IF (cntr = 100) THEN EXIT ' Exit or to a subroutine 'I want to be able call up which one I want to use ' The table is [color=red]IF Chg = 1 Then Loop = 100[/color] [color=blue]If Chg = 0 THEN Loops = 0 [/color] cntr = cntr + 1 * Chg IF (cntr = 100) THEN EXIT ' Exit or to a subroutine LOOPJonny Mac
Thank you for your reply
How ever EXIT is not a commmand in Spin· what command would be close to a EXIT command that is used·in PBasic
What I want to do·is to write a routine in Spin as a Oject·that will do the same thing as it dose in a·PBasic routine
with a Debug so·I can see the state change and see the counter going up in this object
Sam
Post Edited (sam_sam_sam) : 4/27/2010 7:15:34 PM GMT
I think you just go back one indentation:
repeat ctr := ++ctr * ina[noparse][[/noparse]Chg] if (ctr == 100) next instruction...I'm not sure though
Shawn Lowe
When all else fails.....procrastinate!
Here an example with a subroutine that has a parameter mode, which switches btween first and second version.
CON chg = 0 VAR byte cntr PUB main count(0) count(1) PUB count(mode) if mode == 0 repeat cntr := cntr + ina[noparse][[/noparse]chg] if cntr == 100 quit else repeat cntr := cntr + 1 - ina[noparse][[/noparse]chg] if cntr == 100 quitAndy
repeat while cntr < 100 cntr += ina[noparse][[/noparse]chg] repeat cntr += 1 - ina[noparse][[/noparse]chg] until cntr == 100
