A PBasic routine How would you write it to do the same thing in Spin — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2010-04-27 21:46 in Propeller 1
Here is the routine
' {$STAMP BS2}
' {$PBASIC 2.5}
chg    VAR    IN0
cntr   VAR    Byte
' The table is   [color=red]IF Chg = 1 Then Loop = 100[/color]  [color=blue]If Chg = 0 THEN Loops = 0     [/color]
DO
cntr = cntr + 1 * Chg
IF (cntr = 100) THEN EXIT    ' Exit or to a subroutine
LOOP
Thanks to anyone that can help
·Now wanting to learn Spin· Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
Sam
Post Edited (sam_sam_sam) : 4/27/2010 2:03:36 PM GMT
    edited 2010-04-27 14:46
    var byte cntr
    repeat
       cntr := cntr + ina[noparse][[/noparse] 0 ]
       if cntr == 100
          exit
    edited 2010-04-27 14:50
    Thanks Mike Green
    Sam
  • John AbshierJohn Abshier Posts: 1,116
    edited 2010-04-27 14:56
    con
    input_pin = 3
    var
    long ctr
    Pub main
    dira[noparse][[/noparse]input_pin]~
    repeat until ctr == 100
    ctr += ina[noparse][[/noparse]input_pin]
    John Abshier
    edited 2010-04-27 16:26
    What is need to make this an Object
    '' File: ButtonTimeOut.spin
    var
    long ctr
    Pub main  (pin)
    dira[noparse][[/noparse]pin]~
    ctr += ina[noparse][[/noparse]pin]
    I want to Thank John Abshier for his help
    Sam
  • JonnyMacJonnyMac Posts: 9,235
    edited 2010-04-27 16:53
    I think Sam's original code should translate to
    repeat
      ctr := ++ctr * ina[noparse][[/noparse]Chg]
      if (ctr == 100)
        exit
    Jon McPhalen
    Hollywood, CA
    edited 2010-04-27 18:41
    I would like to add this to it as well in the same Object if it can be done
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    chg    VAR    IN0
    cntr   VAR    Byte
    ' The table is   [color=red]IF Chg = 0 Then Loop = 100[/color]  [color=blue]If Chg = 1 THEN Loops = 0     [/color]
    DO
    cntr = cntr + 1 * (1 - Chg)
    'I want to be able call up which one I want to use
    LOOP
    Jonny Mac
    Thank you for your reply
    How ever EXIT is not a commmand in Spin· what command would be close to a EXIT command that is used·in PBasic
    What I want to do·is to write a routine in Spin as a Oject·that will do the same thing as it dose in a·PBasic routine
    with a Debug so·I can see the state change and see the counter going up in this object
    Sam
    Post Edited (sam_sam_sam) : 4/27/2010 7:15:34 PM GMT
  • Shawn LoweShawn Lowe Posts: 635
    edited 2010-04-27 21:01
    S^3,
    I think you just go back one indentation:
    repeat
         if (ctr == 100)
    next instruction...
    I'm not sure though
    Shawn Lowe
    When all else fails.....procrastinate!
  • AribaAriba Posts: 2,690
    edited 2010-04-27 21:37
    exit = quit in Spin
    Here an example with a subroutine that has a parameter mode, which switches btween first and second version.
    CON
      chg  = 0
    VAR
      byte  cntr
    PUB main
      count(0)
      count(1)
    PUB count(mode)
      if mode == 0
        repeat
          cntr := cntr + ina[noparse][[/noparse]chg]
          if cntr == 100
            quit
      else
        repeat
          cntr := cntr + 1 - ina[noparse][[/noparse]chg]
          if cntr == 100
            quit
    Andy
    And some variations of the count repeat loop
      repeat while cntr < 100
        cntr += ina[noparse][[/noparse]chg]
      repeat
        cntr += 1 - ina[noparse][[/noparse]chg]
      until cntr == 100
