Bluetooth to program Propeller?
Hi,
I was just wondering if anyone out there has interfaced a bluetooth module to program the propeller?
The module I am looking at is the Bluegiga WT11.
Cheers
Helen
Cheers
Helen
Ray
Thanks for the reply. I had used the search but forgot to change the search date option so only got one result that wasn't too helpful. I went back and tried again and found lots more! From reading through these I gather that timing issues make it hard to use a bluetooth interface with the propeller programming port.
However there was one post that seemed to suggest it may be possible to download data via a bt module connected to the prop i/o's to write the program data to a secondary eeprom. The prop could then copy the data from the secondary eeprom to the program eeprom. Have I understood this correctly?
Thank again.
Helen
My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
Use Google search for example ... site:forums.parallax.com/forums "f=25" program propeller bluetooth
Unfortunately, a consistent speed serial connection is required to program propeller. Bluetooth serial speed is not consistent.
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
