TWO Propeller books (nearly) on Amazon :-)
Hanno has his "Programming and Customizing the Multicore Propeller Microcontroller" - www.amazon.com/Programming-Customizing-Multicore-Propeller-Parallax/dp/0071664505 and now Harpit has "Programming the Propeller with Spin: A Beginner's Guide to Parallel Processing" - www.amazon.com/Programming-Propeller-Spin-Beginners-Processing/dp/0071716661/ref=pd_bxgy_b_img_b. Way to go guys
Cheers,
Simon
www.norfolkhelicopterclub.com
Announcement: To cut costs in the current economic climate, we have switched-off the light at the end of the tunnel.
Cheers,
Simon
Alex
Cheers,
Simon
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
I have received about half my book back from the McGraw Hill editors and returned the chapters to them with my notes.
The rest should be done in another week or two.
Then to the printers. May be sooner then Jun 22. (Hoping)
Harprit
Parallax Inc.
Follow me at http://twitter.com/ParallaxKen for some insider news.
Does you book cover the LOCKxxx spin commands in detail?. I've come across an issue where I _think_ locked memory might be useful, but none of the documentation seems to clarify it enough for me....
If someone has a a link to some good doco on that topic it would be _REALLY_ appreciated...
Paul
The future is in our hands.
Which way to the future?
I would pick up the book if you haven't already.
Yeah got the book and I have had a browse but it still not helping with my understanding - I get the concept of locks, but not the implementation - was hoping for a good example (with code) so I could be less lost.
So if you know of any sample code that would be marvellous....
I discuss it peripherally but its not what you want I think. I did not have the expertise to guide others.
You only need it if multiple cogs are writing and reading the same longs etc etc etc
Its should be easy enough to work around it if you cant understand the procedure
HSS
It won't be long now.
Harprit
Shipments should start soon.
I got my 10 copies Thursday
Harprit
