Basket ball Boe Bot — Parallax Forums
Basket ball Boe Bot
NewEducatorNewEducator Posts: 11
edited 2010-05-08 13:17 in Robotics
Hi everyone
I have seen a video on You Tube where a pair of Boe Bot shoot basket balls. Here is the link:
Is it possible if anyone knows what kind of accessories of Boe-Bot they are using.
I want to do something similar or same but unable to find any information on it.
Any help would be appreciated.
    edited 2010-04-19 01:36
    That's AWESOME! Thanks for the link.
    edited 2010-04-19 01:44
    The coordination of the two bots using IR is neat. Thats for posting that.
  • sylvie369sylvie369 Posts: 1,622
    edited 2010-04-19 03:01
    The one with the big disk on top is traveling.
    edited 2010-04-19 06:53
    True, both robots should be dribbling the ball at all times. Version 2.0!
    edited 2010-04-19 08:55
    Better yet, a little robot referee should come in from the side blowing a tiny whistle and pointing at the one that's traveling.
  • Tony B.Tony B. Posts: 356
    edited 2010-04-19 13:07
    NewEducator,
    Although there are not any real good close-ups of the bots it appears that they are using standard servos to control the release of the balls into the shooter and to shoot the ball.· The shooter BOT does seem to be using some sort of mechanical advantage to increase speed of the arm.· As mentioned above they seem to be communicating using IR transmitter and receivers (two of each are included in BOE-BOT Kit).· As for the line following, they’re using something like the QTI Sensor.· The rest of the stuff looks like PVC, Cardboard, tape, screws, scrap metal and a lot of good creative thinking.
    I have listed the Parallax part numbers for the items mentioned above.· You will find a manual and often code to help you get started.· Good Luck and don’t forget to post your results on the forums
    Standard Servo - 900-00005
    IR Transmitter - 350-00017
    IR Receiver - 350-00014
    QTI Sensors - 555-27401
    Tony
  • NewEducatorNewEducator Posts: 11
    edited 2010-04-19 13:36
    Thanks, Tony. Your reply really helps. But I am not sure what kind of accessories shooter bot has used. Like, shooting arm..and where do you get these accessories.
    edited 2010-04-19 14:15
    NewEducator,
    I don’t know all they used, but the items you are referring to were built from scratch. I don’t know of any sources to buy a shooting arm. You will have to study the video and try replicating it with wood, plastic and/or metal. Many of these items can be found at either a good hobby shop or Home center.
    Tony
  • WhitWhit Posts: 4,191
    edited 2010-04-19 16:08
    Thanks for posting the great video! Why don't you post a question for the youtube poster?
    Whit+
  • ScopeScope Posts: 417
    edited 2010-04-20 05:19
    Very cool video - too bad Butler didn't . . . well, that's off topic, never mind . . .
  • VeganRobotVeganRobot Posts: 17
    edited 2010-04-20 16:57
    very cool, and inspiring. Hmmm...how do you handle personal fouls with a robot?
    edited 2010-04-20 17:01
    VeganRobot said...
    I thought the First Law of Robotics made them impossible.
  • BlizzardBlizzard Posts: 1
    edited 2010-05-06 21:23
    Hi, I want to do the same project, with some modifications
    I'm gonna build the shooter robot and another person gonna do the basket.
    I have to gather some ideas about the 'arm shooter'
    Contact me
    bye
  • Dave EDave E Posts: 52
    edited 2010-05-06 23:38
    That is a great idea. Good ideas that are easily converted to real life applications.
  • azclawsonazclawson Posts: 10
    edited 2010-05-08 02:04
    Looks like the throwing 'bot used some sort of electronic solenoid actuator wink.gif
    what is "electronic solenoid actuator"
