HEX to DEC?
Hello,
What is the easiest way to convert a HEX number (i.e $F4) to the decimal equivelant (i.e. 244)?
Thank you
"powered by Propeller" domed stickers $1.50 - Find them here
Check out my Design and Technology project for my Higher School Certificate www.ecosureblog.net
The Sarah Myatt Fund - Help Sarah and Her Family Fight Quadriplegia HERE
Thank you
They are being received as a byte via Full Duplex Serial.
If I say this:
num := $F4 if num == 244 ser.str(string("Success!!!"))It will put "Success!!!" to the serial line, because 244 is another representation of $F4 and therefore num == 244.
Is this correct?
Thank you
The prop can't handle decimals so if I do. (15/16)*100 to get 93%
It ends up doing 15/16 which it calculates to be 0 because it ignores decimals, 0 * 100 is 0. So I get 0%
There is a huge difference between 93% and 0%
yay!!
