PropMod 1x1 to Spin Studio Adapter board
Timothy D. Swieter
A forum member ask me to create a PCB so that he could attach PropMod 1x1's to a Spin Studio board for multi-prop experimentation. Attached is the design. I plan on ordering several of these units and selling them for US$2.50 per PCB, or slightly more. The unit basically connects the PropMod 1x1 via the two 2x9 headers to the Spin Studio board via the 2x10 header. The Spin Studio board has 8 I/Os per connector and they are attached to the first few Propeller Pin of the PropMod 1x1 as well as to pins 30/31. In addition there are two solder jumpers on the bottom side of the board so that one can chose to attach SDA/SCL to pins 5/6 of the PropMod 1x1 I/O.
The board is designed to not overhang off of the Spin Studio but rather to point inwards so the edge with the "Marko Module Rev0" would rest on the Spin Studio Prop IC.
Let me know if you are interested in ordering some of these PCBs. Just drop a note on this thread or a PM. It will be two weeks before I get the PCB in house.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
www.tdswieter.com
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
I really haven't advertised or taken part in discussions much on the forums lately due to some personal/family issues, even thought about giving it up. But the news of my demise is premature. I still plan to continue to offer my existing products on into the foreseeable future. Hopefully soon offering some new products as well.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
No problem selling them on your site. We can talk. I ordered 100 units and would love to see people use them.
www.tdswieter.com
Brian
Soon there will be easy, multi-propeller computing for Spin Studio!
www.tdswieter.com
We now have Marko Modules at Brilldea. Tomorrow I will get a basic web site up for ordering, it will be better than sending PayPal invoices. Attached is a scan of the front and back side of the PCB.
www.tdswieter.com
www.brilldea.com/product_markomodule.html
www.tdswieter.com
Lots of propeller based products in stock at affordable prices.
Brian
Anyway, sockets A-C are fast sockets (XLINK, bitrate clkfreq/16, i.e. 5Mb/s @80MHz), socket D only supports slow mode ATM (PropellerLoader, bitrate clkfreq/4400, i.e. ~18Kb/s @80MHz).
www.tdswieter.com
