Basket ball Boe Bot
Hi everyone
I have seen a video on You Tube where a pair of Boe Bot shoot basket balls. Here is the link:
Is it possible if anyone knows what kind of accessories of Boe-Bot they are using.
I want to do something similar or same but unable to find any information on it.
Any help would be appreciated.
Although there are not any real good close-ups of the bots it appears that they are using standard servos to control the release of the balls into the shooter and to shoot the ball.· The shooter BOT does seem to be using some sort of mechanical advantage to increase speed of the arm.· As mentioned above they seem to be communicating using IR transmitter and receivers (two of each are included in BOE-BOT Kit).· As for the line following, they’re using something like the QTI Sensor.· The rest of the stuff looks like PVC, Cardboard, tape, screws, scrap metal and a lot of good creative thinking.
I have listed the Parallax part numbers for the items mentioned above.· You will find a manual and often code to help you get started.· Good Luck and don’t forget to post your results on the forums
Standard Servo - 900-00005
IR Transmitter - 350-00017
IR Receiver - 350-00014
QTI Sensors - 555-27401
Tony
I don’t know all they used, but the items you are referring to were built from scratch. I don’t know of any sources to buy a shooting arm. You will have to study the video and try replicating it with wood, plastic and/or metal. Many of these items can be found at either a good hobby shop or Home center.
Tony
Whit+
I'm gonna build the shooter robot and another person gonna do the basket.
I have to gather some ideas about the 'arm shooter'
Contact me
bye
