Interfacing Sharp Thermal Printer to Stamp — Parallax Forums
MikerocontrollerMikerocontroller Posts: 310
edited 2010-04-18 18:49 in General Discussion
·Hi, I've acquired a 1988 vintage Sharp Thermal Printer / Cassette Interface unit.· The model ·unit is CE-50P.· I can't find any documentation on the pinouts for the interface cable which is built into the unit.· The printer was designed to interface with Sharp organizers and maybe graphic calculators.· I've posted pictures of the unit and a drawing of the·four pin interface cable plug.· I'm thinking of trying to interface this to a BS2 if I can get information about the pinout and communications protocol.· Thank-you.
    edited 2010-04-18 01:31
    Take a look at this site
    Go down the page to where the model # OZ/ZQ-7000
    http://www.promsoft.com/sharp_pocket_computers.htm#basic
    Also look at this site
    http://3d.curtin.edu.au/pce500/rs232-12.html
    I hope this helps
    ··Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    Post Edited (sam_sam_sam) : 4/18/2010 1:38:56 AM GMT
  • MikerocontrollerMikerocontroller Posts: 310
    edited 2010-04-18 17:43
    Thanks sam_sam_sam.· Still no luck finding the 4 pin connector pinouts.· The OZ, ·ZQ, and YO devices use the four-pin interface.· I did find the serial baud configuration which is 9600, 8N1.· I took apart the unit and did not find any labeling on the PC board.· I'll keep trying but I don't have a logic analyzer or·o-scope.· Thanks.
    edited 2010-04-18 18:25
    Did you look at the second link
    The OZ, ·ZQ, and YO devices use the four-pin interface but they also use the 15 - pin interface· as well· might be worth a try
    It look like to me from what·I read that 15 pin header and the four pin header are used on the same pockect computer or device just not all of the pins are used
    ·Now wanting to learn Spin· Thanks for any·idea.gif·that you may have and all of your time finding them smile.gif
    Sam
    Post Edited (sam_sam_sam) : 4/18/2010 6:30:25 PM GMT
    Thanks sam_sam_sam. I'll check again.
