Watchdog with NE555 — Parallax Forums
Watchdog with NE555
jmspaggijmspaggi Posts: 629
edited 2010-04-17 19:15 in General Discussion
Hi there,
I'm trying to build a watchdog with the components.
With 2 NE555 and some BC547 transistor, I'm able to have one output which stay at 1 as long as the input is swtitching from 5 to 0 and then back to 5 in less than a minute.
I built that because I have already 50 NE555 unsused waiting for my on my desk [noparse];)[/noparse]
My concerne is when the output move to 0. I will reset the controller, but the output will stay at 0 until the software start to actiave the pin. But since I'm resetting, the pin stat will never change. Catch 22...
So I'm looking for a solution to have a pulse to 0 when the output move to 0.
Like:
Output
1 ------+                             +-------
0       +----------------------------+
Result
1 ------+  +------------------------------
0       +--+
Any clue how I can do that? Maybe with a capacitor? But how? The pulse don't need to be long. But after that, it should not pulse again until Output come back from 1 to 0.
JM
    edited 2010-04-14 21:46
    Sounds like you need one wired as a missing pulse detector, and have that feeding a second one wired as a monostable. The other option is to have the one wired as a missing pulse detector and feed the output through a capacitor so the edge of the 555 transition produces the reset pulse. You should find both the missing pulse detection and monostable circuits in the data sheet.
  • jmspaggijmspaggi Posts: 629
    edited 2010-04-15 00:45
    I give up [noparse];)[/noparse]
    I tried all day and all evening long and was not able to build it. I think I will simply buy a watchdog component and keep my NE555 for another so good idea [noparse];)[/noparse]
    JM
    edited 2010-04-17 19:04
    jmspaggi,
    Now I'm confused.... wouldn't OUTPUT and RESULT be considered the same thing?
    If the RESULT is indeed the desired result you want from the OUTPUT, then there is a simple capacitor solution in mind that might work for you.
    Beau Schwabe
    IC Layout Engineer
    Hi Beau,
    I think a simple capacitor will have been a good idea, but my electronic knowledge is not good enought even to do that. So I bought some MAX6301 instead and everything is now working fine.
    Initialy, the goal was to have RESULT pulsing low when and only when OUTPUT was going low.
    JM
