BigTrak is back! (sort of)
In case you Bigtrak fans haven't heard...
http://www.bigtrakisback.com/
Maybe after this the prices of the original ones will go below $1,000.00 on eBay?
Jax
If a robot has a screw then it must be romoved and hacked into..
I've toyed with the idea of building one.... maybe on a wood base or something...... The trick is, I'm not sure if I can find a blue photon ray gun though. Such a devastating device can't just be purchased at DigiKey y'know!
"puff"...... Smile, there went another one.
http://forums.parallax.com/showthread.php?p=581950
So, um.... hey there good ol' buddy Mike, buddy ol' PAL.... FRIEND......You wouldn't um, care to send me one for $40 would ya?
the Retrobot platform pretty much IS a Big Trak, or pretty close anyway. A good starting point if anyone wanted to build their own. It's a programmable differential drive robot with wheel encoders that are quite precise and allow accurate navigation. It uses a BS2-class processor, and has 7 unused i/o pins that could be connected to a keypad, a speaker & LEDs. A keypad would be a step backwards from using the Pathfinder code, which lets you teach the unit a precise path by simply driving it with a remote·control.
