Programming help.
I have two input's, (22 and 23) I want one as, One Retriggerable One Shot, the other one as A on off switch. How do I go about adding the Retriggerable One Shot,
to the Program, so I can adjust the Time.
con
·_clkmode·=·xtal1·+·pll16x
·_xinfreq·=·0_500_000
pub·Kid
'dira[noparse][[/noparse]0..19]~~
repeat
····if·ina·[noparse][[/noparse]22]·((((the·input·one·pin22,·need's·to·be··Retriggerabel·One·Shot,·how·does·the·progarm·have·to·look?))))))
······right
····if·ina·[noparse][[/noparse]23]
·········left
pub·right
········dira[noparse][[/noparse]0..19]·:=·%11111111111111111111
········outa[noparse][[/noparse]0..19]·:=·%00000000000000000000
········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00000000010000000000
········outa[noparse][[/noparse]0..19]·:=·%00000000110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000001110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000011110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000111110000000000········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00001111110000000000
pub·left
········outa[noparse][[/noparse]0..19]·:=·%00000000001000000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001100000000
·········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00000000001110000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001111000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001111100000
[noparse][[/noparse]code][noparse][[/noparse]code]
con
pub·Kid
repeat
······right
·········left
pub·right
pub·left
to post samples of your code, paste your code between these two tags, except remove ALL the blank spaces I've inserted inside the brackets:
[noparse][[/noparse] code ]
[noparse][[/noparse] / code ]
That way your code will look like this and all of its indentation will be preservedYou might want to elaborate on exactly what you're trying to do with the various pins, etc. Frankly, I can't understand what you're trying to achieve.
Define a variable old_in and do
is toggling, the led1 stays on and run's for the toggling time...
con _clkmode = xtal1 + pll16x _xinfreq = 0_500_000 pub Kid 'dira[noparse][[/noparse]0..19]~~ repeat if ina [noparse][[/noparse]22] ((((the input one pin22, need's to be Retriggerabel One Shot, how does the progarm have to look?)))))) led1 if ina [noparse][[/noparse]23] led2 pub led1 dira[noparse][[/noparse]0..19] := %11111111111111111111 outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000010000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000001110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000011110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000111110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00001111110000000000 waitcnt(clkfreq/4 + cnt) pub led2 dira[noparse][[/noparse]0..19] := %11111111111111111111 outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001100000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001110000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001111000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001111100000con _clkmode = xtal1 + pll16x _xinfreq = 0_500_000 var long old_in pub Kid 'dira[noparse][[/noparse]0..19]~~ repeat if ina [noparse][[/noparse]22] & !old_in '((((the input one pin22, Was to be Retriggerable One Shot, how does the progarm have to program?)))))) right if ina [noparse][[/noparse]23] left old_in := ina[noparse][[/noparse]22] pub right dira[noparse][[/noparse]0..19] := %11111111111111111111 outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000010000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000001110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000011110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000111110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00001111110000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000 pub left dira[noparse][[/noparse]0..19] := %11111111111111111111 outa[noparse][[/noparse]0..19] := %00000000000000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001000000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001100000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001110000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001111000000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000001111100000 waitcnt(clkfreq/4 + cnt) outa[noparse][[/noparse]0..19] := %00000000000000000000http://forums.parallax.com/showthread.php?p=617192
Inside the manual there is a section on Input/Output basics and Timing. I think it will teach you everything you need to know about making your pins do whatever you want.
Hope that helps.
