Programming help.
I have two input's, (22 and 23) I want one as, One Retriggerable One Shot, the other one as A on off switch. How do I go about adding the Retriggerable One Shot,
to the Program, so I can adjust the Time.
con
·_clkmode·=·xtal1·+·pll16x
·_xinfreq·=·0_500_000
pub·Kid
'dira[noparse][[/noparse]0..19]~~
repeat
····if·ina·[noparse][[/noparse]22]·((((the·input·one·pin22,·need's·to·be··Retriggerabel·One·Shot,·how·does·the·progarm·have·to·look?))))))
······right
····if·ina·[noparse][[/noparse]23]
·········left
pub·right
········dira[noparse][[/noparse]0..19]·:=·%11111111111111111111
········outa[noparse][[/noparse]0..19]·:=·%00000000000000000000
········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00000000010000000000
········outa[noparse][[/noparse]0..19]·:=·%00000000110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000001110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000011110000000000
········outa[noparse][[/noparse]0..19]·:=·%00000111110000000000········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00001111110000000000
pub·left
········outa[noparse][[/noparse]0..19]·:=·%00000000001000000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001100000000
·········waitcnt(clkfreq/4·+·cnt)
········outa[noparse][[/noparse]0..19]·:=·%00000000001110000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001111000000
········outa[noparse][[/noparse]0..19]·:=·%00000000001111100000
[noparse][[/noparse]code][noparse][[/noparse]code]
con
pub·Kid
repeat
······right
·········left
pub·right
pub·left
to post samples of your code, paste your code between these two tags, except remove ALL the blank spaces I've inserted inside the brackets:
[noparse][[/noparse] code ]
[noparse][[/noparse] / code ]
You might want to elaborate on exactly what you're trying to do with the various pins, etc. Frankly, I can't understand what you're trying to achieve.
Define a variable old_in and do
is toggling, the led1 stays on and run's for the toggling time...
http://forums.parallax.com/showthread.php?p=617192
Inside the manual there is a section on Input/Output basics and Timing. I think it will teach you everything you need to know about making your pins do whatever you want.
Hope that helps.
