MGOS- Micro Graphical Operating System for Propeller
Hello!
I would like to present this demonstration GUI under development.
Use of various libraries parallax.
Es: TV / Mouse / Graphics.
Use the resolution 259x192 in 4 colors
The biggest problem I found that there is not enough memory to include others libraries.
Hopefully with the Prop II, there is no more problem.
As a demonstration and more sufficient.
Bye!
Lucas68
Bye!
Lucas68
May the road rise to meet you; may the sun shine on your back.
May you create something useful, even if it's just a hack.
I hope to shrink the program as possible, to show something really works.
However, this is an idea!
tubular
Post some code when you get far enough.. I'd kinda like to see this in the flesh (so to speak)...
[noparse]:)[/noparse]
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
When is it scheduled for completion?
Will it run on the demo board with added software and SD card?
humanoido
Post Edited (humanoido) : 4/13/2010 8:55:50 AM GMT
I plan soon will complete at least the part of management software gdi, to upload all the forum.
I would, include at least 4 routines important for the effective operation:
Managing Files on SD Card.
Routine monitoring of input and output pins of the propeller.
Routine beep speaker.
Real time clock
I have under construction the new board Prop Vic-II, which includes SD Card and Port Expander and Mic In.
As soon as pr completed the project on the previous uploader forum.
Anyway I will update you on developments.
Lucas 68.
do you think, you can have some compatibility with Sphinx?
Christof
humanoido
Is now in testing, to correct some errors.
the date of September 2010, will release the first version, with the following features.
1) Reading sd card fat16.
2) Realtime clock
3) Customizing color of the desktop.
4) management in / out ports for interfacing sensors and drive relays, programmable timer. (Using additional hardware interface, in production)
5) the audio beep function when used alone.
everything will be posted on the forum, I accept suggestions for improvements.
Lucas 68.
