MGOS- Micro Graphical Operating System for Propeller — Parallax Forums
Lucas68Lucas68 Posts: 12
edited 2010-07-15 08:42 in Propeller 1
Hello!
I would like to present this demonstration GUI under development.
Use of various libraries parallax.
Es: TV / Mouse / Graphics.
Use the resolution 259x192 in 4 colors
The biggest problem I found that there is not enough memory to include others libraries.
Hopefully with the Prop II, there is no more problem.
As a demonstration and more sufficient.
Bye!
Lucas68
1600 x 1200 - 291K
1600 x 1200 - 305K
1024 x 768 - 437K
  • jazzedjazzed Posts: 11,803
    edited 2010-04-12 23:23
    Cool [noparse]:)[/noparse]
    May the road rise to meet you; may the sun shine on your back.
    May you create something useful, even if it's just a hack.
  • Kevin WoodKevin Wood Posts: 1,266
    edited 2010-04-12 23:36
    edited 2010-04-12 23:56
    Nice start for MGOS!
    Lucas68 said...
    Hello!
    <SPAN class=long_text id=result_box><SPAN title="Vorrei presentare questa interfaccia grafica dimostrativa in fase di sviluppo." style="BACKGROUND-COLOR: #fff" closure_uid_4mfh9u="435">I would like to present this demonstration GUI under development.
    <SPAN title="Utilizza varie delle librerie parallax." style="BACKGROUND-COLOR: #fff" closure_uid_4mfh9u="436">Use of various libraries parallax.
    <SPAN title="Es: Tv/Mouse/Graphics." style="BACKGROUND-COLOR: #fff" closure_uid_4mfh9u="437">Es: TV / Mouse / Graphics.
    <SPAN title="Usa la risoluzione 259x192 a 4 colori" style="BACKGROUND-COLOR: #fff" closure_uid_4mfh9u="438">Use the resolution 259x192 in 4 colors
    <SPAN title="Il problema maggiore che ho riscontrato che non c'
  • Lucas68Lucas68 Posts: 12
    edited 2010-04-13 00:01
    windows and menus, and the pointer really work, style windows! are not only designed graphics demo.
    I hope to shrink the program as possible, to show something really works.
    However, this is an idea!
  • TubularTubular Posts: 4,774
    edited 2010-04-13 00:10
    Great Start... Keep going!
    tubular
    edited 2010-04-13 00:18
    edited 2010-04-13 00:36
    Nice Work Indeed!
    Post some code when you get far enough.. I'd kinda like to see this in the flesh (so to speak)...
    OBC
    Are you Propeller Powered? PropellerPowered.com
    Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
    edited 2010-04-13 04:57
    Wow that is impressive.
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2010-04-13 05:24
    What software did you use to generate the virtual circuit boards?
    edited 2010-04-13 06:00
    looks like altium's work.
  • Andrey DemenevAndrey Demenev Posts: 423
    edited 2010-04-13 06:23
    That's 3dmax - see Prop-VIC thread
    edited 2010-04-13 08:29
    Wow - totally fantastic!
    When is it scheduled for completion?
    Will it run on the demo board with added software and SD card?
    humanoido
    Post Edited (humanoido) : 4/13/2010 8:55:50 AM GMT
    edited 2010-04-13 09:18
    hello!
    I plan soon will complete at least the part of management software gdi, to upload all the forum.
    I would, include at least 4 routines important for the effective operation:
    Managing Files on SD Card.
    Routine monitoring of input and output pins of the propeller.
    Routine beep speaker.
    Real time clock
    I have under construction the new board Prop Vic-II, which includes SD Card and Port Expander and Mic In.
    As soon as pr completed the project on the previous uploader forum.
    Anyway I will update you on developments.
    Lucas 68.
  • Christof Eb.Christof Eb. Posts: 1,597
    edited 2010-04-13 18:38
    Hello Lucas 68,
    do you think, you can have some compatibility with Sphinx?
    Christof
    edited 2010-04-14 01:01
    How about posting some demo software to play with?
    humanoido
    edited 2010-07-15 05:57
    Any updates on this project?
    Hello!
    Is now in testing, to correct some errors.
    the date of September 2010, will release the first version, with the following features.
    1) Reading sd card fat16.
    2) Realtime clock
    3) Customizing color of the desktop.
    4) management in / out ports for interfacing sensors and drive relays, programmable timer. (Using additional hardware interface, in production)
    5) the audio beep function when used alone.
    everything will be posted on the forum, I accept suggestions for improvements.
    Lucas 68.
