Higher voltage -- ENDed — Parallax Forums
PJAllenPJAllen BannedPosts: 5,065
edited 2010-04-13 20:09 in General Discussion
Subject Terminated, Polluted by Spamhole (aka "Sujana".)
Post Edited (PJ Allen) : 4/14/2010 10:38:20 PM GMT
    edited 2010-04-12 15:20
    PJ Allen,
    Wouldn't the use of TOGGLE be more effective than PULSOUT ?
    Beau Schwabe
    IC Layout Engineer
    edited 2010-04-12 16:04
    PJ: You had mentioned "Taser" in the other HV thread. I built a BS1 game with a mild shocking circuit. Low-tech, it used but VERY effective. The BS1 buzzed a relay (~5 Hz) to switch pulsating DC from a single C-cell (1.5V) through the 6V secondary of a cheap Radio Shack filament transformer. High voltage (a good tingle) came out of the primary side, routed to metal contacts on the game controllers. Input voltages higher than 1.5V give proportionally higher output shock voltages.
    I found out pretty quickly that most people (including big strong macho guys) refuse to play if they know a shock is coming. Best to keep it a surprise. The thrill of discovery awaits!
    edited 2010-04-12 17:42
    PJ Allen,
    The use of TOGGLE will just make the output wave more symmetrical ... i.e. 50% duty which I think is what you really would want.
    As far as 'taser' goes, I wouldn't call it that, but you can gain a respectable more effective 'punch' from a charge pump design rather than directly pulsing from a battery.
    Here is a patent document with the information you need.
    www.google.com/patents/about?id=sCEKAAAAEBAJ&dq=6500210
    page 5 of the PDF shows a basic circuit... the SK3950 is just a basic SCR ... The SK9442 can be omitted and the Collector terminal can be tied directly to ground. The circuit basically charges a capacitor and when the trigger threshold (set by a voltage divider) of the SCR is met, the capacitor is discharged into a tiny pulse transformer and the cycle starts all over again.
    page 9 of the PDF shows a way to gate the SCR to allow frequency control. i.e. from a Stamp or Propeller
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 4/12/2010 5:54:48 PM GMT
    edited 2010-04-13 02:52
    PJ Allen,
    I understand the concept "Once the Art Dept got hold of the schematic all bets were off.", it's happened many times to myself, but what mags are you referring to that are buggy?
    Beau Schwabe
    IC Layout Engineer
    edited 2010-04-13 04:07
    erco i have one of these fun but you are right people don't want to play once they realise they may get a shock.
  • SujanaSujana Posts: 1
    High Voltage Info is your reference source for researching, and learning about high voltage. A good place to start is with the definition of high voltage. You can use our online and email resources for selecting HV components, power supplies, modules, instruments, services and systems. Browse through the website and return often as we are building a reference library for your use. Our focus is on everything related to high voltage, including standards, useful links and recommendations on HV products. If you need information on a high voltage power supply, HV capacitor, HV connector or any other HV product, this is the place to check first. We’re your high voltage reference.
    Ford Mustang Parts
