Higher voltage -- ENDed
PJAllen
BannedPosts: 5,065
Subject Terminated, Polluted by Spamhole (aka "Sujana".)
Post Edited (PJ Allen) : 4/14/2010 10:38:20 PM GMT
Wouldn't the use of TOGGLE be more effective than PULSOUT ?
Beau Schwabe
IC Layout Engineer
I found out pretty quickly that most people (including big strong macho guys) refuse to play if they know a shock is coming. Best to keep it a surprise. The thrill of discovery awaits!
The use of TOGGLE will just make the output wave more symmetrical ... i.e. 50% duty which I think is what you really would want.
As far as 'taser' goes, I wouldn't call it that, but you can gain a respectable more effective 'punch' from a charge pump design rather than directly pulsing from a battery.
Here is a patent document with the information you need.
www.google.com/patents/about?id=sCEKAAAAEBAJ&dq=6500210
page 5 of the PDF shows a basic circuit... the SK3950 is just a basic SCR ... The SK9442 can be omitted and the Collector terminal can be tied directly to ground. The circuit basically charges a capacitor and when the trigger threshold (set by a voltage divider) of the SCR is met, the capacitor is discharged into a tiny pulse transformer and the cycle starts all over again.
page 9 of the PDF shows a way to gate the SCR to allow frequency control. i.e. from a Stamp or Propeller
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 4/12/2010 5:54:48 PM GMT
I understand the concept "Once the Art Dept got hold of the schematic all bets were off.", it's happened many times to myself, but what mags are you referring to that are buggy?
Beau Schwabe
IC Layout Engineer
Ford Mustang Parts
