PJ: You had mentioned "Taser" in the other HV thread. I built a BS1 game with a mild shocking circuit. Low-tech, it used but VERY effective. The BS1 buzzed a relay (~5 Hz) to switch pulsating DC from a single C-cell (1.5V) through the 6V secondary of a cheap Radio Shack filament transformer. High voltage (a good tingle) came out of the primary side, routed to metal contacts on the game controllers. Input voltages higher than 1.5V give proportionally higher output shock voltages.
I found out pretty quickly that most people (including big strong macho guys) refuse to play if they know a shock is coming. Best to keep it a surprise. The thrill of discovery awaits!
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ ·"If you build it, they will come."
The use of TOGGLE will just make the output wave more symmetrical ... i.e. 50% duty which I think is what you really would want.
As far as 'taser' goes, I wouldn't call it that, but you can gain a respectable more effective 'punch' from a charge pump design rather than directly pulsing from a battery.
page 5 of the PDF shows a basic circuit... the SK3950 is just a basic SCR ... The SK9442 can be omitted and the Collector terminal can be tied directly to ground. The circuit basically charges a capacitor and when the trigger threshold (set by a voltage divider) of the SCR is met, the capacitor is discharged into a tiny pulse transformer and the cycle starts all over again.
page 9 of the PDF shows a way to gate the SCR to allow frequency control. i.e. from a Stamp or Propeller
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 4/12/2010 5:54:48 PM GMT
I understand the concept "Once the Art Dept got hold of the schematic all bets were off.", it's happened many times to myself, but what mags are you referring to that are buggy?
IC Layout Engineer
High Voltage Info is your reference source for researching, and learning about high voltage. A good place to start is with the definition of high voltage. You can use our online and email resources for selecting HV components, power supplies, modules, instruments, services and systems. Browse through the website and return often as we are building a reference library for your use. Our focus is on everything related to high voltage, including standards, useful links and recommendations on HV products. If you need information on a high voltage power supply, HV capacitor, HV connector or any other HV product, this is the place to check first. We’re your high voltage reference.
Wouldn't the use of TOGGLE be more effective than PULSOUT ?
Beau Schwabe
IC Layout Engineer
Here is a patent document with the information you need.
www.google.com/patents/about?id=sCEKAAAAEBAJ&dq=6500210
Beau Schwabe
IC Layout Engineer
Beau Schwabe
IC Layout Engineer
Ford Mustang Parts
