Exchanging data between two props — Parallax Forums
teddypteddyp Posts: 14
edited 2010-04-09 12:46 in Propeller 1
As the topic says, I'm currently trying to exchange some data from a master prop to a slave prop (ran out of cogs). I've downloaded the inter-prop communication object and the modified serial object from the forums and am having no luck with them whatsoever. I'm definitely not grasping some concept here. If I put some dummy data in say...
  DataOut:=$55
  TX(@DataOut)              'Transmit Data Packet
shouldnt it send it out? I'm getting nothing at the receiving side. I'm not worried about speed, and my main loop is updating every second, so is there an easier way to send a set of numbers, say the time in military (HHMMSS-> 171832) from one prop to the other? Can I just initialize full duplex serial on both cogs and push data through somehow that way? Below is the code I've altered slightly. Thanks in advance.
Full Code Master
CON                                                     'Constant definition block
  _clkmode        = xtal1 + pll16x                      'Using PLL, set frequency to 80MHz
  _xinfreq        = 5_000_000                           'Input Crystal frequency. Dev board is 5MHz
  TX_Pin        = 11
  PacketSize    = 1024          '<- Number of Packet Longs to transmit ; 1 Long = 32 data Bits
OBJ                                                     'Object definition block
  display         : "TV_Text"                           'Reference TV_Text object
VAR
  long    DataOut[noparse][[/noparse]PacketSize]                   'Variable definition block
PUB Main
  display.start(12)                                     'Start display on pin 12
  display.out(CLS)                                      'Clear screen
  display.str(string("Serial test"))                    'test
  WaitCnt(cnt + clkfreq*2)                              'delay
  display.out(CLS)                                      'Clearscreen
   repeat                                               'Repeat forever
     DataOut:=$5555_5555
     waitcnt(cnt + clkfreq)                             'Wait one clock cycle and repeat
'     waitcnt(cnt + clkfreq * 2)                         'Wait 2 clock cycles and repeat
PUB TX(_DataOut)
    cognew(@TX_Propeller_COM,_DataOut)                     'Send Data
DAT
TX_Propeller_COM        org
              mov       TX_PinMask,             #1         'Create Pin Mask for Input/Output pin
              shl       TX_PinMask,             #TX_Pin
              andn      outa,                   TX_PinMask 'Preset Pin LOW
              or        dira,                   TX_PinMask 'Make Pin an Output LOW
              mov       DataIndex,              par        'Read Data Location into DataIndex
LoadData      rdlong    Buff,                   DataIndex  'Read Data Value from Indexed location
              add       DataIndex,              #4         'Increment Index value
              nop
              rol       Buff,                   #1   wc    'Read Buff Bit31 into "C" ; Rotate Buff left by 1
              or        outa,                   TX_PinMask 'Make Pin HIGH (50nS)         SYNC
              andn      outa,                   TX_PinMask 'Make Pin LOW  (50nS)         SYNC
              muxc      outa,                   TX_PinMask 'Make Pin HIGH or LOW (100nS)  DATA
              nop
              andn      outa,                   TX_PinMask 'Make Pin LOW (750nS)
              djnz      DataSamples,            #LoadData  'Check to see if there are more data samples
              andn      dira,                   TX_PinMask 'Make Pin an Input
              cogid     temp                               'Get this COG ID
              cogstop   temp                               'STOP this COG
'initialized variables
DataSamples   long      PacketSize
'un-initialized variables
DataIndex     long      0
Buff          long      0
'aliased variables
temp
TX_PinMask    long      0
Full Code slave
  CLS             = $0                                  'Clear screen
  RX_Pin          = 3
  PacketSize      = 1024          '<- Number of Packet Longs to receive ; 1 Long = 32 data Bits
VAR                                                     'Variable definition block
  long   rcvddata
  long   DataIn[noparse][[/noparse]PacketSize],ReadyFlag  '<-ReadyFlag must follow immediately after the Data
PUB Main  | rx_buff, i, seed, v
  displayString(1,3, string("serial comm test"))
  WaitCnt(cnt + clkfreq)                              'delay some
  display.out(CLS)
  rcvddata := RX(@DataIn)
     display.str(string("testdata: "))
     display.str(rcvddata)
PUB RX(_DataIn)
    ReadyFlag := 1                                         'Read Data
    cognew(@RX_Propeller_COM,_DataIn)
    repeat while ReadyFlag == 1                            'Wait here until data is ready
DAT
RX_Propeller_COM        org
              mov       RX_PinMask,             #1         'Create Pin Mask for Input/Output pin
              shl       RX_PinMask,             #RX_Pin
SYNC_Start    waitpeq   RX_PinMask,             RX_PinMask 'Wait for SYNC - HIGH
              waitpne   RX_PinMask,             RX_PinMask 'Wait for SYNC - LOW
              test      RX_PinMask,             ina wc     'Read RX pin into "C"
              rcl       Buff,#1                            'Rotate Buff left and place "C" in Bit0
              wrlong    Buff,                   DataIndex  'Write Data Value to Indexed location
              djnz      DataSamples,            #SYNC_Start'Check to see if there are more data samples
              mov       temp,                   #0         'Clear the Ready Flag
              wrlong    temp,                   DataIndex
'uninitialized variables
DataIndex     long      0
Buff          long      0
'aliased variables
temp
RX_PinMask    long      0
Post Edited (teddyp) : 4/9/2010 12:39:35 PM GMT
    edited 2010-04-09 04:40
    teddyp,
    Hi, welcome to the forum!
    just a few things in the code...
    For both:
         - the TX(master) and RX(slave), the number of packets you are sending I reduced
           to 1 since the test data that you are sending is only the length of a LONG.
         - for the attached code I moved the RX and TX pins to pin 7 ... this just
           works better with my setup on this end.  You should be able to use whatever
           pins you want.
    The TX(master):
         - is fine, the way it is, no big changes...
    The RX(slave):
         - the received data is automatically placed into [b]DataIn[/b] so there is no need
           to define a second variable [b]rcvddata[/b]
         - instead of trying to display the data with [b]display.str(rcvddata)[/b], use
           [b]display.str(@DataIn)[/b] instead
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 4/9/2010 4:47:36 AM GMT
    edited 2010-04-09 05:10
    teddyp said...
      DataOut:=$55
    I used your - unchanged - transmitter code (with the exception that I filled the data array with a fixed pattern). I also connected a POS detector counter to the TX pin and the data is definitely leaving the prop (all bits are accounted for). So it looks like either your receiver has some synchronisation issues or the connection between both is unreliable!?
    Incidentally, do you mind adjusting the comment for long DataOut[noparse][[/noparse]PacketSize] in your original post, ATM it's hard to read your post when you have to scroll horizontally.
    Post Edited (kuroneko) : 4/9/2010 1:12:09 PM GMT
  • teddypteddyp Posts: 14
    Beau,
    Thank you so much for the reply. I will be implementing your recommendations very shortly. I have been playing with the code you wrote for this and the object for inter-prop communication and was wondering if I was even sending the data right. The seed was throwing me off, but I believe I understand that concept now. Just generating the "random" string to send data for testing.
    @kuroneko,
    Thanks for the info too. It does seem to be my receive system. Also, thanks for pointing out that comment. I was wondering why it was 80 screens wide and was checking, but I missed that comment somehow. Fixed now... I hope.
    Thanks again you two. I love these parallax forums, you guys are really helpful here and quick with responses.
    -ted
