Propeller-Robot-ControlBoard #28230 + 2 x 12 volt VDC - motors
nomad
hi,
i want buy the PropellerRobotControlBoard
# 28230
with this board i want control
2 x 12volt VDC-Motors with a single
12volt Batterie with 3.7Ah.
aka for each motor with max 1.85Ampere.
Question (1): is this possible with this Board ???
(the Board have 2.8ampere each channel)
Question (2): on the Board-Doku.pdf
"28230-propellerrobotcontrolbrd-v1.0.pdf"
on page 5
quotation:
is this important for me???
i think, when the input (from 12volt batterie)
output (to 2 x 12vollt VDC-Motors)
its ok ????
but my english is not so good
thanks for tips, hints and help
regards
nomad
# 28230
on page 5
quotation:
CAUTION: The input voltage (VIN) is also the motor voltage. For this reason you should not use a wall adapter or battery higher than the maximum voltage of the motors when enabling the motors (power switch moved to the third (right) position, see below) or you may damage or reduce the life of the motors.
its ok ????
regards
nomad
I've tried 12V input with the board. Everything works fine.
Nyamekye,
thanks a lot for your answer,
it's fine
thanks
regards nomad
if you need any code to start from let me know. I just finished the basic drive setup.
1 Parallax Propeller Robot Control Board
1 Memsic MX2125 accelerometer/ tilt
1 Parallax Ping))) ultrasonic sensor
a few motors and a whole lot of chaos!
inthanks for your advice.
in few days i can working with this board and a PPDB
regards nomad
excuse this second posting
if you have code-sniippets for the start please make a attachment
im working with 2 motors + 12VBatterie + this Board + the PropellerProfessionalDevelopmentBoard
1 x compass, 7 x Pings
thanks for your help and the code
regards nomad
You don't have to change the motor pins since the connectors have default pins and are filled in allready.
:::::::Code is attached to this post :::::::::
Enjoy!
many thanks for your code.
it's a help for me to starting
regards nomad
sometimes later.
i make short test with your Autonomous Driver_MAIN_FILE.spin
the stpin-compiler makes a error at:
-> SetField( x_pos, y_pos - sectordist, 2 ) with
-> expected an instruction or variable
in your code i find nothing about this instructions???
have you some hints or tips???
thanks for the code and the pwm-object
regards nomad
You will see that same sentence three times. Just remove them.
after remove first tests only for compile ok
in the next few days i'm starting my coding
thanks a lot
regards nomad
thanks,
regards nomad
