Propeller-Robot-ControlBoard #28230 + 2 x 12 volt VDC - motors — Parallax Forums
nomadnomad Posts: 276
edited 2010-04-12 07:01 in Propeller 1
hi,
i want buy the PropellerRobotControlBoard
# 28230
with this board i want control
2 x 12volt VDC-Motors with a single
12volt Batterie with 3.7Ah.
aka for each motor with max 1.85Ampere.
Question (1): is this possible with this Board ???
(the Board have 2.8ampere each channel)
Question (2): on the Board-Doku.pdf
"28230-propellerrobotcontrolbrd-v1.0.pdf"
on page 5
quotation:
CAUTION: The input voltage (VIN) is also the motor voltage.
For this reason you should not use a wall adapter or battery higher
than the maximum voltage of the motors when enabling the motors
(power switch moved to the third (right) position, see below) or you
may damage or reduce the life of the motors.
is this important for me???
i think, when the input (from 12volt batterie)
output (to 2 x 12vollt VDC-Motors)
its ok ????
but my english is not so good
thanks for tips, hints and help
regards
nomad
  • KyeKye Posts: 2,200
    edited 2010-04-08 13:37
    The robot controller board can handle 12V. Just make sure that neither of your motors draw more than 2.8 As per channel.
    I've tried 12V input with the board. Everything works fine.
    Nyamekye,
  • nomadnomad Posts: 276
    edited 2010-04-08 15:21
    hi Nyamekye,
    thanks a lot for your answer,
    it's fine
    thanks
    regards nomad
  • BotdocterBotdocter Posts: 271
    edited 2010-04-08 18:33
    I have just bought the same setup. Works great! I use 10 penlite batteries (AA 3900 mAh)
    if you need any code to start from let me know. I just finished the basic drive setup.
    1 Parallax Propeller Robot Control Board
    1 Memsic MX2125 accelerometer/ tilt
    1 Parallax Ping))) ultrasonic sensor
    a few motors and a whole lot of chaos!
    edited 2010-04-09 09:11
    hi Botdocte
    inthanks for your advice.
    in few days i can working with this board and a PPDB
    regards nomad
    edited 2010-04-09 09:16
    hi Botdocter
    excuse this second posting
    if you have code-sniippets for the start please make a attachment
    im working with 2 motors + 12VBatterie + this Board + the PropellerProfessionalDevelopmentBoard
    1 x compass, 7 x Pings
    thanks for your help and the code
    regards nomad
    edited 2010-04-11 03:34
    The code is cleaned up and should work out of the box. Just remember to change the PING))) Pin to whatever pin your using
    You don't have to change the motor pins since the connectors have default pins and are filled in allready.
    :::::::Code is attached to this post :::::::::
    Enjoy!
    edited 2010-04-11 07:22
    hi Botdocter,
    many thanks for your code.
    it's a help for me to starting
    regards nomad
    edited 2010-04-11 08:03
    hi Botdocter,
    sometimes later.
    i make short test with your Autonomous Driver_MAIN_FILE.spin
    the stpin-compiler makes a error at:
    -> SetField( x_pos, y_pos - sectordist, 2 ) with
    -> expected an instruction or variable
    in your code i find nothing about this instructions???
    have you some hints or tips???
    thanks for the code and the pwm-object
    regards nomad
    edited 2010-04-11 11:19
    You can remove those lines. They're from some other code im working on.
    You will see that same sentence three times. Just remove them.
    edited 2010-04-11 14:37
    hi, Botdocter,
    after remove first tests only for compile ok
    in the next few days i'm starting my coding
    thanks a lot
    regards nomad
    edited 2010-04-11 16:24
    Sobyou got it to work? Great! Enjoy!
    hi Botdocter,
    thanks,
    regards nomad
