Imfrared help
I need help with the infrared for the BS2. I have a infrared LED and infrared 3 pin reciever, a homework board, and tons of resistors. I need help with the schematics too. What i wanted to do is point a tv remote at the reciever and press a button on the remote so that it sends a signal. then i want the BS2 to store that signal and when a button on the BS2 is pressed it will send that signal (and then to have new button programed in then justreset program)
I don't know the code for infrared but i need the code to look something like this:
VAR's:
Signal
Get_signal:
· getsignal
·· if Signal = 0
··· then repeat
···· else goto Main
getsignal:
·in1 = Signal
Main:
·wait untill·(in2= 1)···············' when the btn is pressed
· then freqout·Signal· ·········· ' then broadcast infrared signal varible
·· repeat
Need help ASAP! Thanks guys!
"When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
· Thomas Jefferson
VAR's:
Signal
Get_signal:
· getsignal
·· if Signal = 0
··· then repeat
···· else goto Main
getsignal:
·in1 = Signal
Main:
·· repeat
· Thomas Jefferson
- Stephen
So, when you send the data back out, you probably need to modulate the data again...... With that said I dunno what your doing with the sent data either.
For my information, which Ir receiver are you using? I've been toying with Ir as well.
"puff"...... Smile, there went another one.
· Thomas Jefferson
www.parallax.com/Portals/0/Downloads/docs/prod/sic/WebIR-%20v1.1.pdf
· Thomas Jefferson
Might be possible, depending on the particular timing and how many different commands you want to store. You'll probably need to use an external 555 timer to generate a 38 kHz carrier and just have the Stamp modulate that.
First you'll need to verify that your remote uses IR (some new ones are RF) and is transmitting on a 38-40 kHz carrier . Got a friend with an oscilloscope?
Next, you should familiarize yourself with the Sony protocol, which Parallax has documented very well. You can extrapolate from that to try to tackle non-Sony codes.
· Thomas Jefferson
Still a good idea, though. Maybe since you're not going to follow up on that, now I'll do it and get rich. Thanks a million!
-I think they already have these types of remotes out on the market, I just wanted to make my own. I'm using some highpower IR 940nm LEDS to get my distance extended. Also, since the LEDS are modulated at 38khz, you can apply a much higher current than the LEDs rating since it is on for only microseconds at a time.
"The man who smiles when things go wrong has thought of someone to blame it on."
-Lucky[size=-1][/size]
Post Edited (Lucky) : 4/6/2010 5:35:57 AM GMT
