Stingray Code by Steve Norris
Hey All,
In the May/June issue of Robot Magazine, James H. Phelan, MD did a great review of the Stingray. Attached to that article was a review by Steve Norris titled, "The Parallax Stingray - a so-called "expert's" review" Well, Steve Norris is an expert. Check out his website at http://www.norrislabs.com/·if you have any doubts.
Anyway, Steve promised in his article to post some of his·code for the Stingray - It is now ready for download at www.botmag.com·at this link http://www.botmag.com/source-code/StingrayDemos.zip
Take a look - it is an education. Thanks Steve!
P.S. This is the same issue with a review of the PropScope (by Steve too) and an article called "Basic Transportation" by erco (aka Eric Ostendorff)·featuring his Retrobot. His code is also now ready to download too.
Whit+
Post Edited (Whit) : 3/12/2010 10:26:53 PM GMT
Whit+
I'll check out that Stingray code tonight.
Check out the Propeller Wiki·and contribute if you can.
I'm not using RF, but I believe the code is designed to work without it.
Shouldn't there be a GoFWD method that invokes the Go method i.e.:
if m_Auto Blocked(1) Avoid(2) AvoidWall(3) ' GoFWD(4 ) ' <== Should this method call go here? PRI GoFWD(priority) if m_CurrentPriority => Priority if m_CurrentDir == Mov_Rev ' to be on the safe side, may never happen. Halt ' Disable all lower priority behaviors m_CurrentPriority := Priority DispMsg(string("Reversing Dir")) elseif m_CurrentDir == Mov_Halt Go m_CurrentPriority := Priority DispMsg(string("Moving Forward")) else ' Release control m_CurrentDir := Mov_Fwd DispMsg(string(" "))The code was meant as and example of the behavior based framework I use for all my robots. I leave it up to the reader to build their own robust behaviors based on the type of mission they wish their machine to perform.
Steve Norris
www.norrislabs.com
