Stingray Code by Steve Norris — Parallax Forums
WhitWhit Posts: 4,191
edited 2010-04-06 15:15 in Robotics
Hey All,
In the May/June issue of Robot Magazine, James H. Phelan, MD did a great review of the Stingray. Attached to that article was a review by Steve Norris titled, "The Parallax Stingray - a so-called "expert's" review" Well, Steve Norris is an expert. Check out his website at http://www.norrislabs.com/·if you have any doubts.
Anyway, Steve promised in his article to post some of his·code for the Stingray - It is now ready for download at www.botmag.com·at this link http://www.botmag.com/source-code/StingrayDemos.zip
Take a look - it is an education. Thanks Steve!
P.S. This is the same issue with a review of the PropScope (by Steve too) and an article called "Basic Transportation" by erco (aka Eric Ostendorff)·featuring his Retrobot. His code is also now ready to download too.
Whit+
Post Edited (Whit) : 3/12/2010 10:26:53 PM GMT
    edited 2010-03-12 22:39
    That issue was awesome. Erco's bot, the stingray and the prop scope. The PropScope article finally convinced me to go ahead and get one to replace the ancient old scope I have, and with the stuff I am getting myself into with electronics lately, I'm going to need it.
    I'll check out that Stingray code tonight.
    Check out the Propeller Wiki·and contribute if you can.
  • wyzard28wyzard28 Posts: 24
    edited 2010-04-05 16:38
    Norris' Stingray code seems incomplete. I compiled and loaded my Stingray with it and it just sits there, pings pinging, but no go. There's a GO method that's never accessed. Perhaps that's the problem?
    I'm not using RF, but I believe the code is designed to work without it.
    Shouldn't there be a GoFWD method that invokes the Go method i.e.:
        if m_Auto
          Blocked(1)
          Avoid(2)
          AvoidWall(3)
    '     GoFWD(4 )             ' <== Should this method call go here?
    PRI GoFWD(priority)
      if m_CurrentPriority => Priority
        if m_CurrentDir == Mov_Rev                          ' to be on the safe side, may never happen.
          Halt
          ' Disable all lower priority behaviors
          m_CurrentPriority := Priority
          DispMsg(string("Reversing Dir"))
       elseif m_CurrentDir == Mov_Halt
          Go
          DispMsg(string("Moving Forward"))
       else
          ' Release control
          m_CurrentDir := Mov_Fwd
          DispMsg(string(" "))
  • norris56norris56 Posts: 69
    The code would be incomplete if you removed the RF section. It is there that I initiate the forward command from my remote control. I use the remote control to override the behaviors. Your solution is a good one if you want the robot to start up on its own.
    The code was meant as and example of the behavior based framework I use for all my robots. I leave it up to the reader to build their own robust behaviors based on the type of mission they wish their machine to perform.
    Steve Norris
    www.norrislabs.com
