how to control a high voltage stuff with microcontroller
hi all i goat my first microcontroller yesterday as a learning kit at radio shack it is called parallax basic stamp bc-2 item # 90005
i was playing, discovering and learning with it a few days but know am and up with tons of questions
first question is how can i control lets say a 120v lamp with it
next question is this thing only has 9 volt Battery sou its max output is 9 volts lets say i want to control a few 12 volt motors with it how can i do that?
i can figure out by my own how to program but i need help to how to connect higher voltage stuff to microcontroller?
please go easy on me i am new in this microcontroller world
?next question is this thing only has 9 volt Battery sou its max output is 9 volts lets say i want to control a few 12 volt motors with it how can i do that?
2) Nuts and Volts Column #6 discusses how to control higher voltages and higher currents using a Stamp I/O pin. Download it from Parallax and read it.
3) Controlling any kind of AC device is potentially very dangerous. You need to know what you're doing. For 120VAC devices up to a few Amps, you can use an appropriate relay or SSR (Solid State Relay). Parallax makes an Industrial Control Board that provides for several such relays. EFX-TEK also has a Solid State Relay board. Using either one is still potentially very dangerous. You can get killed.
it would been good if you wrote a direct link to that page thx any way
The Basic Stamp and transistor drive the relay. The diode is critical to protect them when the relay coil power is disconnected.
Chris Savage
Parallax Engineering
A very quick and easy way to start controlling high voltage right away with your basic stamp.
http://www.grainger.com/Grainger/items/6C900?Pid=search
Chris Savage
You need to look at Column #6, not volume #6. Column #6 is in Volume #1: ...... http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/vol1/col/nv6.pdf
Rick
http://tangentsoft.net/elec/movies/
There is no problem that can't be solved with a suitable amount of explosives!
EOD Memorial
