help help help!
Please can anyone help me to understand how to change the TV driver with the VGA driver in the Graphics_demo.spin project??
I need to use the same graphics library on a VGA monitor instad of TV.
Please help me.........
thenaks and best regards
maurizio
maurizio
Leon Heller
Amateur radio callsign: G1HSM
I'm·using Propeller from 2 days ago·, i· came from ARM·Cortex m3 processors and this is really new fo me·.....If you know where is possible to find some working demos that uses graphics library and VGA this will help me a lot.
Tnks and best regards
Maurizio
search search search obex obex obex vga vga vga
Post Edited (StefanL38) : 3/28/2010 5:38:54 PM GMT
but yes...the demo is right but i find a lot of problems to include the graphics lib (arc, line, plot etc)
As you can see, inside the demo is possible to test only Text graphics (boxes are created using characters)
I know tha i'm pretending too much, but im sure that you can help me!
Thanks and best regards
maurizio
there is also my 640x240 bitmapped vga driver in obex
The Propeller only has 32KB of memory, so the amount of graphics possible in VGA is limited - if you need higher resolution and more color, one of my products - the Morpheus board - can do that.
mikronauts.com/products/morpheus/
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
i think that this is a good start....yes the morpheus is bigger and offers more memory but for the use that i need think that popeller is enought.
The file suggested is really good but offers too few graphics option like double text etc (instead of graphics.spin library) but now i'll work on it...thank you and hope to solve soon my problem.....
Maurizio
The problem was the screen[noparse][[/noparse]....] sub.....wrong parameters!!
thank you all again!
Maurizio
Graham
Thank you again.....ah, now i've other big problems with Prop just to use Graph and text at the same time......i hate Prop!
Hope to post soon!!!
regards
Maurizio
Can you please edit your subject to make it more relevant. Use the pencil icon on the first post to get access to the subject title.
