help help help! — Parallax Forums
help help help!
pennellinopennellino Posts: 6
edited 2010-03-31 13:25 in Propeller 1
Please can anyone help me to understand how to change the TV driver with the VGA driver in the Graphics_demo.spin project??
I need to use the same graphics library on a VGA monitor instad of TV.
Please help me.........
thenaks and best regards
maurizio
  • LeonLeon Posts: 7,620
    edited 2010-03-28 17:10
    Download the VGA driver and use that instead of the TV driver.
    Leon Heller
    Amateur radio callsign: G1HSM
  • pennellinopennellino Posts: 6
    edited 2010-03-28 17:22
    thanks Leon for your answer, but Yes, i have changed the driver , but there are lots of constant tables and Vars that needs to be set.
    I'm·using Propeller from 2 days ago·, i· came from ARM·Cortex m3 processors and this is really new fo me·.....If you know where is possible to find some working demos that uses graphics library and VGA this will help me a lot.
    Tnks and best regards
    Maurizio
    edited 2010-03-28 17:30
    C:\Program Files\Parallax Inc\Propeller Tool v1.2.7\Examples\Library\VGA_Demo.spin
    search search search obex obex obex vga vga vga
    Post Edited (StefanL38) : 3/28/2010 5:38:54 PM GMT
    edited 2010-03-28 17:35
    Oh my god....thanks all for help!
    but yes...the demo is right but i find a lot of problems to include the graphics lib (arc, line, plot etc)
    As you can see, inside the demo is possible to test only Text graphics (boxes are created using characters)
    I know tha i'm pretending too much, but im sure that you can help me!
    Thanks and best regards
    maurizio
    edited 2010-03-28 17:40
    Look for Chip's 512x384 bitmapped vga object in the obex
    there is also my 640x240 bitmapped vga driver in obex
    The Propeller only has 32KB of memory, so the amount of graphics possible in VGA is limited - if you need higher resolution and more color, one of my products - the Morpheus board - can do that.
    mikronauts.com/products/morpheus/
    pennellino said...
    maurizio
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
    Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
    Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-03-28 17:48
    thank you Bill...
    i think that this is a good start....yes the morpheus is bigger and offers more memory but for the use that i need think that popeller is enought.
    The file suggested is really good but offers too few graphics option like double text etc (instead of graphics.spin library) but now i'll work on it...thank you and hope to solve soon my problem.....
    Maurizio
    edited 2010-03-29 15:11
    FOUND!!!!
    The problem was the screen[noparse][[/noparse]....] sub.....wrong parameters!!
    thank you all again!
    Maurizio
    edited 2010-03-29 16:22
    Why not post your code so others may benefit
    Graham
    edited 2010-03-31 13:13
    Yes, sure!· But before i've to adjust some parts of code that doesn't works fine!
    Thank you again.....ah, now i've other big problems with Prop just to use Graph and text at the same time......i hate Prop!
    Hope to post soon!!!
    regards
    Maurizio
    pennellino: Welcome to the prop and the forum. As you have found, there is plenty of help here.
    Can you please edit your subject to make it more relevant. Use the pencil icon on the first post to get access to the subject title.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
