Very interested, I need a quick pointer
I basically come seeking a recommendation.
I am very interested in the Propeller and currently have an SX development kit. I am kind of
used to the LIF socket design and on the fly development.
I would like to have a 40 pin dip development kit of the Propeller.
Only thing is I don't want a fixed chip on a board, I would rather have something
like I am familiar with. Something I can buy more chips for as I use them.
I navigated the getting started the closet thing I seen was the 40-pin DIP education kit.
Would this be fit the profile I am looking for?
The Education kit is a great place to start, with an excellent manual and labs.
The Professional Development Board is also a joy.
Welcome to the Prop!
T o n y
On the Propeller you don't actual load your code into the propeller chip. It gets loaded into the EEPROM. So changing propeller chips will NOT run different code. You would have to change the EEPROM chip to do that.
Bean
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
I just have to decide which one I want. The external EEPROM is interesting also good to know.
So I will need at least one for every Propeller I use in a project.
Its a very impressive piece of silicon.
-Thetniv
8x8 color 80 Column NTSC Text Object
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
