Very interested, I need a quick pointer — Parallax Forums
ThetnivThetniv Posts: 2
edited 2010-03-27 21:58 in Propeller 1
I basically come seeking a recommendation.
I am very interested in the Propeller and currently have an SX development kit. I am kind of
used to the LIF socket design and on the fly development.
I would like to have a 40 pin dip development kit of the Propeller.
Only thing is I don't want a fixed chip on a board, I would rather have something
like I am familiar with. Something I can buy more chips for as I use them.
I navigated the getting started the closet thing I seen was the 40-pin DIP education kit.
Would this be fit the profile I am looking for?
  • TonyWaiteTonyWaite Posts: 219
    edited 2010-03-26 07:53
    Hi Thetniv,
    The Education kit is a great place to start, with an excellent manual and labs.
    The Professional Development Board is also a joy.
    Welcome to the Prop!
    T o n y
  • BeanBean Posts: 8,129
    edited 2010-03-26 11:38
    Thetniv,
    On the Propeller you don't actual load your code into the propeller chip. It gets loaded into the EEPROM. So changing propeller chips will NOT run different code. You would have to change the EEPROM chip to do that.
    Bean
    Use BASIC on the Propeller with the speed of assembly language.
    PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
    March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
  • parts-man73parts-man73 Posts: 830
    edited 2010-03-26 15:26
    My SpinStudio system has a socketed DIP propeller and a socketed EEPROM. Plus add-on peripheral modules to allow you to have a flexible system that can evolve with your abilities and needs.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
  • kf4ixmkf4ixm Posts: 529
    edited 2010-03-26 15:48
    The PropLab from Spinvent http://www.spinvent.co.uk/PropLAB.html·it also has socketed eeprom and 40 pin prop. i have one and love it.
  • K2K2 Posts: 694
    edited 2010-03-26 17:15
    I just checked out both uController and Spinvent for the first time. Wow, what fantastic systems! The PropLab is too cool for words, and the SpinStudio modular approach is perfect for a particular project that just got moved to the front of the line. Very nice!
    edited 2010-03-26 17:31
    Also, the PropLab from spinvent is compatible with the Propeller Education Lab Fundamentals Text (found here), you just have to change the pin numbers in the text example code to match the prop lab, but this is a very trivial task.
  • ThetnivThetniv Posts: 2
    edited 2010-03-27 12:38
    Thank you all so very much for taking the time to help!
    I just have to decide which one I want. The external EEPROM is interesting also good to know.
    So I will need at least one for every Propeller I use in a project.
    Its a very impressive piece of silicon.
    -Thetniv
    edited 2010-03-27 21:42
    You are gonna get hooked. Just so you know [noparse]:)[/noparse]
    8x8 color 80 Column NTSC Text Object
    Safety Tip: Life is as good as YOU think it is!
  • W9GFOW9GFO Posts: 4,010
    There is also the Propeller Platform.
    Rich H
    The Simple Servo Tester, a kit from Gadget Gangster.
