Laser Range Project
Hello All,
I have been searching google and this forum for a simple laser range finder but I have not had any luck so far. I am looking for something that does not have to have the greatest range (up to 50feet or so) and I need to control it with either a prop or basic stamp. The project involves gathering distances (1" to 50') and using the Ping is not going to work with the distances that I need.
If there is a better suggestion instead of using a laser system please feel free to share it.
Jesse
Jesse
I've also been searching but haven't come across anything yet. What I really want is just the optical part of a laser "disto" ($150ish for a complete disto at hardware stores)
Maxbotix have some great long range ultrasonic sensors which might do what you need, depending of the size of the target you're trying to detect.
cheers
tubular
Powered by enthusiasm
Like a wiseguy, I figure: buy one of these at the hardware store and intercept the data that goes to the display and latch/sample it.· Easier said than done.· Somebody should buy me a few of these and maybe we can find out how.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
You are correct. Here's the link with some experimental results on p2 of the thread.
http://forums.parallax.com/showthread.php?p=812333
The TSL1401 has a wide field of view, it'd need some kind of zoom lens for 50'
I need a pretty accurate range finder that I do not think a sonar range finder can get me because of the pin point accuracy that I am looking for.
Jesse
What resolution?
Signature space for rent!
Send $1 to CannibalRobotics.com.
I do appreciate everyones help and when I get this project going I will be sure to post it up here.
Jesse
