Anyone use Dynamic DNS ?
You may have noticed that www.propbasic.com and my other web sites have been down lately.
I had a static IP address with my ISP. But they have switch carriers and now I can no longer get one.
They have suggested using Dynamic DNS and that I should be able to find a provider for free.
I've done some searching, but I'd like to know if anyone here uses this ? And who you use for the service ? And if they charge a fee ?
Bean.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134
March 2010 Nuts and Volts article·http://www.parallax.com/Portals/0/Downloads/docs/cols/nv/prop/col/nvp5.pdf
Bean.
I use DynDNS.org. It is free, but there are some "gotchas" to the free service. For all of the free services that I am aware of, you are "stuck" using some type of "pre-defined" domain name. You can pick the "sub domain", but have to use one of "their" domains at the end. For example you would have to go with propbasic.dnsalias.com or one of the other choices. For a fee ($29.95 per year) you could have them handle the DNS for propbasic.com and be "good to go". When/if I do any hosting at home, I'll have to go that route. There are other plans, depending on how many domains, etc.
[noparse][[/noparse]A thought just hit me as I was typing this. You _may_ be able to get www.propbasic.com to work for free (at least as a test), by defining www as a CN record at your current DNS, and have it re-direct to something like propbasic.dnsalias.com.]
I use mine to keep an IPSec VPN established between home and work (work is static, home is dynmaic). There is a client app that runs on one of my PCs that keeps the server and dnsalias.com up to date as the address changes. The connection has been very reliable, and I've only experienced a very brief outage in the VPN when the address changes.
I know there are other providers out there, but haven't had a reason to look. I find it easier/cheaper to have my hosting done eslewhere (using GoDaddy now). Don't need the hardware or bandwidth, maintenance headaches, etc. I've got mixed feelings about GoDaddy, but I haven't really worked at the sites much, so I'm not the right person to ask.
John R.
Click here to see my Nomad Build Log
As John R. pointed out above, there are some 'gotchas' to the free service.
I've never used a router or embedded device to update my dyndns details though, it's always been done by a script on my servers.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should use WD40.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" 16:9 LCD Composite video display, eProto for SunSPOT, PropNET, PolkaDOT-51
www.tdswieter.com
Bean how Big is your site?
Peter KG6LSE
"Carpe Ducktum" "seize the tape!!"
peterthethinker.com/tesla/Venom/Venom.html
Never underestimate the bandwidth of a station wagon full of tapes hurtling down the highway. —Tanenbaum, Andrew S.
LOL
I've got plenty of room on my hosting account. Would you like a spot? PM me.
OBC
Are you Propeller Powered? PropellerPowered.com
Visit the: PROPELLERPOWERED SIG forum kindly hosted by Savage Circuits.
www.tdswieter.com
