5 volt regulators and layout problems
Alright, here is the back story. I made a board with Propeller Platform and Schmartboard features combined with battery holders on the back. Please find layout attachment. So far the board has a 2.1 mm barrel jack, a slide switch, and a regulator on it. The first regulators from Digikey put out 11.6 volts. The second batch from Digikey also put out 11.6 volts. The same regulator from Newark just got here and, you guessed it, it puts out 11.6 volts. After cleaning the board with 99.96% dry IPA the regulator still puts out 11.6 volts. The regulator is an LM2940-5.0. What did I do wrong on the layout. Do Digikey and Newark buy parts from the same place? I've never had a problem with the larger through hole versions of the same part. While people with more experience than me inspect the file I'm going to start board #2 and see if I get the same result. Yes, I got the same result on the second board. I don't have a power filter capacitor for the incoming DC. Will this keep a regulator from working properly?
MOORE'S LAW: The capabilities of electronics shall double every 18 months.
cloyd's corollary: Hardware is easy, software is hard.
Post Edited (yarisboy) : 3/25/2010 12:47:21 AM GMT
Results: With the 3.3 volt regulator the 5 volt regulator is putting out more than 12 volts now. The 3.3 volt regulator is putting out 11.6 volts with or without a load.
I may have to scrap these boards and use the same regulators used on the Schmart board. The rest of the parts for these boards will be here tomorrow but I'm not optimistic. The 3.3 volt regulator is a LM3940-3.3/NOPB. I'll put on all the caps before I give up and open the trash bin.
Post Script: The data sheets recommend capacitor values to use to use on these regulators. They state that they must have capacitance to achieve stable regulation and transient response.
Post Edited (yarisboy) : 3/25/2010 3:22:53 AM GMT
The Propeller Platform is laid out for VRs similar to LD1085 type where ground is one of the outer pins and IN is the middle and Out is the the other outer pin. The LM2940 series is like the LM7805 with GND in the middle and In and Out on the outers.
If you were not aware of this and just copied the pinouts from the Prop Platform, it would explain the voltages you are getting.
cheers ... BBR
cheers ... brian riley, n1bq, underhill center, vermont
The Shoppe at Wulfden
www.wulfden.org/TheShoppe/
www.national.com/an/AN/AN-1148.pdf
You would get more help if you could convert your .pcb file to something (e.g. .pdf, .gif, etc.) that everyone can read.
EDIT: Hmmm... I just looked at them on my other computer and there are no connecting lines whatsoever. I guess it's really not any help at all. Sorry.
Leon Heller
Amateur radio callsign: G1HSM
Leon Heller
I brought his file into ExpressPCB under Bootcamp on my iMac and took a screenshot
cheers ... BBR
Leon Heller
Post Edited (Leon) : 3/26/2010 12:18:27 AM GMT
Jim,
that's pretty good. How did you convert his file into PDF?
Jim
Okay, I get it now. I'm surprised the details came out so well doing it that way.
thanks,
Mark
looking at your pcb, I'm not seeing how you're bring 12vdc to your 5vdc reg. unless you've update the traces in the area of the 2.1mm jack.· If you have an unpopulated board still, put your jack on, power it up and see if you have 12v on your 5 and 3 volt traces.· Nothing obvious to me except the jack connection to the pcb.
Kevin
Bad spellers of the world untie!
Also make sure you don't have any shorts between VIN and V50. Measure it using an ohmmeter with the power disconnected.
What is the value of the '2940's output cap? It needs at least a 22uF low (but not too low) ESR (e.g. tantalum) cap to be stable.
The grounds on the regulators are punched through to the ground plane with multiple vias for both electrical and thermal reasons. I'm cautious about heat sinking with regulators that can source one amp and are less than half the size of the through hole versions I'm familiar with.
Post Edited (yarisboy) : 3/26/2010 6:12:40 AM GMT
What about the excessive track length between the capacitors and the regulators that I mentioned earlier?
A schematic would still be useful.
Leon Heller
Post Edited (Leon) : 3/26/2010 1:42:31 PM GMT
Leon Heller
