SUCCESS!!! Propeller uSD Datalogger in a micro package (Propmodule 1x1 and Para
 WBA Consulting
WBA Consulting
                    This is still in the works but I have it far enough to post some pictures.....
For this year's Polar Bear Plunge (see link below my signature), I am remaking my "plungelogger" with a propeller. Last year's plungelogger was made with a BS2P40 and apart from the self-inflicted program error, it worked out great. However, since it was rather large for my pocket and power hungry, I started the new one.
It's based on a Propmodule 1x1 board and a Parallax uSD Card Adapter board. I modified the 1x1 board to make use of a 5 pin header where the 4 pin programming header would go. The 5th pin is connected with a jumper wire to VDD. Also, to make the adapter card sit diretly onto the 1x1 module, I cut the trace from P1 on the prop and tied that hole to VDD with a jumper wire. This allows the uSD card to piggyback the 1x1 module. I added two 2 pin headers on the end of the 1x1 which is where the SHT11 will attach. (P16 needs to be tied to ground, that mod will come later). I am also changing the uSD adapter over to some Samtec low profile headers so that the piggyback will be at minimal height. This will also allow the 1x1 module to be used for other projects without having to unsolder the uSD module.
to do list:
1. low profile headers
2. program validation
3. battery connection
4. waterproof enclosure
5. icewater test
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Post Edited (WBA Consulting) : 3/23/2010 6:10:06 AM GMT
to do list:
5. icewater test
Andrew Williams
WBA Consulting
Parallax will add a sponsorship to your Polar Bear Plunge page. BTW, that page doesn't clearly mention the charity - can you clarify for us?
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
@mctrivia: yes, I finally did. It was hiding in a small case with 3 cypress chips. I think they were trying to brainwash it........ I looked through 6 boxes and 3 cases to find it. I need to get my stuff re-organized. I made a mess of everything when trying to complete the reverse geo-cache project.
Andrew Williams
WBA Consulting
Propeller-Based Reverse Geo-Cache Birthday Present Project
We'll be in for fifty bucks and maybe some on-site cheering and support.
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
I do have an accelerometer, so maybe I should add that? What else should I track while I run into freezing water? A heart rate monitor would be perfect!
ps.
I had a chance to try it out last Saturday at a local community center pool plunge, but I couldn't find my 1x1 module in time. They had 100 blocks of ice that were tossed in shortly before we jumped in. The water was 52 degrees before the blocks of ice. Would have been a good test for my setup.
Andrew Williams
WBA Consulting
Post Edited (WBA Consulting) : 1/26/2010 4:07:15 PM GMT
I will be modifying my existing datalogger code to this pinout this weekend.
Andrew Williams
WBA Consulting
Weather was beautiful, with temperature a nice cool 59 degrees. I finished my datalogger the night before with a few changes from my original thoughts. I ended up using a larger case than originally planned, because I went with a 9 volt battery since I didn't have time to verify how long my old, re-purposed, 3.6v cordless phone batteries would last. Everything went well with the plunge and my datalogger. Water temperature was measured at 44.5 degrees. It was a blast! I ended up raising $545 for Special Olympics (a quick thanks to Gadget Gangster and Parallax for their donations).
Anyhow, here's a few pics. Uses my PowerTwig, McTrivia's Propmodule1x1, Parallax's uSD module, one of my SHT11 modules, a waterproof Otterbox 1000 case, a reed switch for "through the case" resetting, and a "Powered by Propeller" dome sticker.
Andrew Williams
WBA Consulting
