Quad/Hexa-Copter using Propeller, Gyros, Accelerometers, Compass, Pressure & GP - Page 4 — Parallax Forums
1246717
    edited 2010-03-19 05:06
    Roy: Yes your idea is great and we will all learn from your experiences and may be able to help. I don't see it working out any cheaper than the 9DOF board with simple code to just output the sensor info so we can use the prop to do the filtering. I am unsure if we need all the sensors either, but the cost within the board framework is small. If I were doing a pcb it could be left off. The compass is 3-axis $20 so I think it takes care of tilt (probably by our software). Maybe we need it, maybe we don't.
    Digital Compass = magnetometer
    Buying little modules works out expensive and then all the connections are a potential source of problems in a vibration area.
    Hanno: Thanks for your input. I know you have a lot of experience here.
    So I think I may go the 9DOF route and use a proto board initially until I know what to put on a specific pcb.
  • Nick McClickNick McClick Posts: 1,003
    edited 2010-03-19 05:18
    I have the Acc_Gyro, it's a 5DOF IMU, uses a LIS331AL 3 axis accel and LPR550AL 2 axis gyro - it's $50.
    One thing I've also been thinking about is thermopiles. If your intent is just to stay level with the ground, maybe just use 2 thermocouples and a gps?
    Propeller Forums RSS Feed!
    Gadget Gangster - Share your Electronic Projects
  • SzabiSzabi Posts: 58
    edited 2010-03-19 10:30
    Roy, you are totally right. Less sensors could do the job but I'm still beside Cluso's idea with the ready made 9DOF.
    As many sensors as better results we can achieve by mixing all measurements. It's more difficult to build it but it is worth.
    We need to use as many sensors as we can for a safe flight. (especially for autonomous flight)
    I'm working in telecom and it happened to me so many times that a GPS or a compass showed me a totally wrong way because of the MW radiations around me.
    Easily can happen that we will flight near to a telecom tower (GSM etc), or that we fly in into a MW fresnel zone and our instruments will play crazy. Unfortunately I don't know the effect of radiation on gyros or tilt sensors but I definitely have bad experience with compass and GPS. (to fool a compass a metallic rooftop is plenty enough)
    By writing the code we will need to take this in count and avoid mixing for example a flagrant compass value.
    As soon as we decide what way we will go and fix the prototype component list, I will test all of those in such circumstances.
    Regarding ultrasonic measurements, I have not that bad experience. Was trying to measure distance on different surfaces, grass, wood, sand ...etc. the measured values differs just a few cm's. Should not be a big thing to hit the ground from a hight of aprox. 5 cm smile.gif Any other experiences in landing or ultrasonic measurements?
    Cheers
    Szabi
    edited 2010-03-19 11:02
    Ultrasonics will be fine to measure from the bottom of the quadcopter. If it is not level it will not matter as the error becomes less as you approach the ground.
    Nick: I will PM you over the w/e.
    edited 2010-03-19 18:23
    Another ground sensor... 6"-255"
    Sparkfun ultrasonic http://www.sparkfun.com/commerce/product_info.php?products_id=639 $25
    The sensor only is $5 but we are not allowed to copy the circuit nor given the info for the pic they use (not sure if we could get the prop to do the ADC). This could still be a nice project.
  • hover1hover1 Posts: 1,929
    edited 2010-03-19 19:27
    I not sure you need to add a ADC based on what I read in the Data Sheet:
    · All interfaces are active simultaneously
    · Serial, 0 to Vcc
    · 9600Baud, 81N
    · Analog, (Vcc/512) / inch
    · Pulse width, (147uS/inch)
    Although the serial is slow IMHO, I do like that the device will run at 3.3V and serial is 0 to VCC.
    I also like the custom beam widths.
    Trying to understand the 0"-6" in the spec sheet. Is it optional or programmable? Relying on 6" for final approach is too small. It would be great to switch to 6" when you know you are almost there for landing.
    Jim
    Cluso99 said...
  • BuildThingsBuildThings Posts: 31
    edited 2010-03-19 20:43
    I figured I would take one for the team and purchased the 9DOF from sparkfun to start some testing. Since I am impatient, it will be here tomorrow morning.
    My thoughts are to do some bench testing and then log some data with the 9DOF as a payload on a fixed wing plane and a copter tomorrow.... weather in Virginia is supposed to be amazing!!!
    Let me know if anyone has anything specific they would like tested or measured. I plan on logging the serial data stream at different attitudes from both on the bench and in the air, and posting video and raw data here. This should give us some preliminary data and a jump start on coding and debugging tools.
    I wanted to try to put together a test gimbal(ish) rig with some servos so we can simulate true sense and response. If anyone has any ideas for that chime right in. My initial brainstorm was a platform that can be controlled in X/Y to simulate the attitude change with another platform on top of it with the 9DOF, that would be driven by servos acting as the thrust of the engines. I'm thinking about veting out the... tilt object, 12 block code.. etc
    If anyone is interested I can connect the Propeller up to my lantronix Xport (serial to ethernet) along with a web cam for a remote test rig. I have a static IP, and for any serious coders that don't feel like forking out the $125, or sending test code back at forth.. this might help things along.
    -John
    edited 2010-03-19 21:12
    Jim: The module contains a PIC and it is programmed to give 1"-255" outputs, but <6" gives 6" so 6"-255". It must be >=6" off the ground when you power it up so it can calibrate itself. The ADC is required if we just use the transducer and make our own circuit.
    I have had my reality check. I can make this better and cheaper... So, here's what I think I will do... (after a little more sleep)
    • Build 3 pcbs, each 2"x2" with mounting holes in the 4 corners, so they stack or
    • Build 1 pcb 3.5"x3.5" with mounting holes in the 4 corners, combining the circuitry of the 3 pcbs
    • Top pcb - "Controller"
      • Contains prop chip & eeprom
      • 8 PWM inputs from RC
      • 8 PWM outputs to ESC
      • Serial I/O (propplug format) to "Sensor" pcb
      • Connector to GPS serial I/O (PMB-248 or PMB-648)
      • Hopefully some method to attach the GPS above this pcb (unsure how)
      • MicroSD connector (for datalogging)
      • Connector for unused prop pins (e.g. for a ZigBee)
      • Power connector 5V/3V3/GND
    • Middle pcb - "Sensor"
      • Contains Atmega328
      • Gyro 3-axis (+pitch duplicated)
        • LPR530AL or LRP550AL (pitch & roll)
        • LPY530AL or LPY550AL (pitch & yaw)
      • Accelerometer 3-axis
        • ADXL345
      • Digital Compass 3-axis
        • HMC5843
      • Pressure & Temperature
        • BMP085
      • Connection and circuit for Ultrasonic Transducer
        • Sen-00635 or
        • Sen-08505 + Quad OpAmp
        • Ultrasonic Transducer to be relocated to "Power Distribution" pcb
      • Connector for Ultrasonic Transducer
      • Connector for LED underneath "Power Distribution" pcb
      • Serial I/O (propplug format) to "Controller" pcb
    • Lower pcb - "Power Distribution"
      • Connectors for LiPo Battery (+V/GND & 5V/GND)
      • Connectors for up to 8 ESC (2 wire solder or screw terminals each)
      • Connectors for 5V/3V3/GND output to "Sensor" & "Controller" pcbs
      • Onboard 3V3 voltage regulator LM1117DT-3V3
      • Onboard 5V voltage regulator LM1117DT-5V (optional)
      • Connector 2-pin for Ultrasonic Transducer
      • Ultrasonic Transducer (underside of pcb to face ground, offset from center)
      • Ultrahigh intensity LED (underside of pcb, offset from center)
    The 9DOF software is LGPL so it can be used if desired, or we can write our own. We can decide how much is in the prop and how much is in the Atmega. My preference is to place as much in the prop as we can and just use the Atmega to sample all the sensors and pass the results to the prop for processing.
    Have I missed anything ??? Ambitious, but hey, may as well include the options for it. Any comments ???
    edited 2010-03-19 21:35
    Ray,
    Looks good so far except for HMC5843 Digital Compass buried between boards. I am no expert but intuition would lead me to expose that sensor above all circuitry.
    I'm not even sure how that sensor, (or any magnetometer for that matter), would react in the middle of 4-8 motors with some pretty powerful magnets. Just thinking outloud.
    I'm excited about the reaction from the community, and John for getting the actual hardware to play with! Thanks John!
    Jim
    edited 2010-03-19 21:55
    John: Our posts crossed. Sounds great. Look forward to seeing some data smile.gif
    Jim: The motors and escs are located as far away as possible (motors at the ends of the beam and esc nearby). The electroncs (+compass) are in the centre of the quadcopter. The GPS must be on the top for it to see the satellites. I figure the centre is the best place for the sensors, but this method would allow them to be reversed as I am using cables to join the pcbs, not stack plugging as I think vibration would ultimately be a problem.
  • Robert TRobert T Posts: 71
    edited 2010-03-19 22:00
    I am in.
    Leave a few pins to control servos in case we decide to add camera mount later.
    hover1:
    My motors are ~12 inches from the center board area, is that distance too close? I was also thinking about mounting the compass on a post sticking up above everything a few inches (I've seen this in a few other projects).
    I was hoping that the calibration feature of the compass would help account for the frame and motors that are always there and at the same locations relative to the compass.
    Tonight I plan to work on my code to get all the sensors read and filtered (kalman and PID) and have that drive some servos using my PPDB test circuit. I can play around with tilting and turning and shifting the PPDB around and see the output in PST and on the servos. That should let me dial in the basic code structure and such, then tomorrow I can put everything on the Protoboard and get that onto my frame with motors and start testing/tuning the code with the tethers keeping it safe.
    Also, if you build a frame with landing gear / feet and stuff, then it's likely that you could have 6 inches between the Ultrasonic sensor and the actual ground while the craft is on the ground (on it's feet). With all this talk here of using Ultrasonics for detecting the ground when close, I have been considering using one or two of my PING)))'s on mine.
    Check out the Propeller Wiki·and contribute if you can.
    edited 2010-03-19 22:11
    The data sheet on the compass module with tilt compensation (OS400-T) describes the affect of rotating magnets close to the unit. This unit is sold on the Sparkfun site.
    Here is the link. Look on page 21
    http://www.sparkfun.com/datasheets/Sensors/Magneto/OS4000_Compass_Manual.pdf
    Basically
    Distance Error(degrees)
    2" 90.0
    5" 10.0
    9" 1.6
    11" 0.2
    How this applies to four motors, who nows
    edited 2010-03-20 06:28
    Robert: The motors will be some distance away so hopefully minimal interferance. We can always raise the pcb above the frame. Yes, there is provision for up to 8 servos, so camera control is possible, etc.
    Roy: Yes, with feet we can get the 6" easily.
    I am going to use carbon fibre rectangular tubes
    http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=9012
    http://hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=8711
    I can get similar locally 1m long
    http://www.hobbymodelwarehouse.com.au/index1.html
    A 1m length can be cut almost in half and the shorter piece in half again to give a quad with ~250mm length·(radius) arms.
    If I make a round pcb 3.5" dia with power one side and ground the other, the connectors for the motors, etc (as described for the "Power Distribution" pcb above), plus with holes for quad & hex beams, we could use two of these to hold the frame together at the centre also smilewinkgrin.gif
    The make 1 pcb 3.5" dia to combine the "Sensor" and "Controller" pcbs described above smilewinkgrin.gif
    A guess... A set of pcbs might cost ~$30 if I can get enough interest. Does this sound interesting???
    Post Edited (Cluso99) : 3/20/2010 6:33:51 AM GMT
    edited 2010-03-20 08:58
    Here is the Frame pcb - Power Connectors to be added for the Motor ESC's, one at each frame post (whatever they are called). It will take a QuadCopter or HexaCopter design with 3.2mm dia holes using rectangular tubing (carbon fibre). Use 2 pcbs, one on top of the frame and one at the bottom located at the centre of the posts. Only 1 pcb is loaded, but it is cheaper to have 2 identical pcbs fabricated.
    I will try and use a similar method for the motor mounts.
    Postedit:
    Here is a video of a quad using 3-blade propellors 8x4" http://tom.poub.free.fr/blog/index.php?gallery/x-ufo-perso/adxrs150-v1/adxrs150_v1_040#gallery·and the blades http://www.hobbycity.com/hobbyking/store/uh_viewitem.asp?idproduct=5249·and http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=5247
    Post Edited (Cluso99) : 3/20/2010 10:16:57 AM GMT
    edited 2010-03-20 13:05
    Cluso,
    for approximately the same price we could buy and use the Parallax Ping ultrasonic module. That needs only a single pin. (the measured distance is 2cm-3m, this should be fine)
    Another solution would be to buy the 5$ sensors and use the measurement technic used by the Parallax Ping module smile.gif
    Sz
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2010-03-20 13:54
    I wouldn't use a PCB to join the arms it seems a recipe for broken tracks in the event of a crash or hard landing. Better to clamp the carbon rods too if you can rather than drill them if you can.
    Graham
  • dMajodMajo Posts: 861
    edited 2010-03-20 14:20
    Cluso,
    I am not interested in RC modelling, but when a friend of mine showed me this you came on my mind
    http://www.draganfly.com/uav-helicopter/draganflyer-x6/specifications/
    http://www.draganfly.com/uav-helicopter/draganflyer-x6/features/stability.php
    http://www.draganfly.com/uav-helicopter/draganflyer-x6/specifications/controller.php
    · Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
    edited 2010-03-20 14:38
    Graham: Does the idea of using a pcb to hold the arms make sense? We could always use a 3rd pcb to be the power connector. It would just make sense that they be identical pcbs to keep cost down. Certainly the rods (square carbon fibre tubes) could be clamped down between the pcbs. However, I have allowed for holes at 0.5", 1" & 1.5" radius out from the center. I would expect just the 0.5" & 1" would be drilled into the tube. We could clamp near the outer edge on either side, but would have to decide the tube size before I could put these holes in, or leave the user to drill these (not so good).
    Thinking a little further, I would rather the arm break than the pcb mounting (i.e. the mounting plate) because that could result in damage to the sensor/conroller pcb as well. Better for the arm to be sacrificial.
    I would expect to do a similar thing on the outer ends of the arms for the motor mounting.
    Szabi: Yes I will have another look at the Parallax Ping))) sensor. Done. This sensor uses more current than the one I found. However, its interface is exceptionally easy so I think its a goer :-)
    The GPS is also from Parallax - The PMB-248 is cheaper so may as well use it. BTW the elevation on GPS's is not that accurate. I have had readings on my boat out to sea of >20m when 2m should be the actual value and this is not a tidal error. However, over a flight time, its accuracy is likely to be fairly consistent so as long as we record this when taking off, it should be close for bringing the craft back close to the ground.
    Does anyone have the exact measurements and hole sizes for motor mounts? Also, are there differences for the various motors? My mounting plate/motor is currently interstate.
    dMajo: Nice find, thankyou. An alternative using 3 arms and 6 motors - interesting.
    Post Edited (Cluso99) : 3/20/2010 3:03:51 PM GMT
    edited 2010-03-20 14:59
    dMajo - thanks for the link, that Dragonfly device is inspiring. I was curious on the cost so I clicked on the request quote button. The base model is US$16,995.00!!!!!!!
    Timothy D. Swieter, E.I.
    www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
    www.tdswieter.com
    edited 2010-03-20 15:03
    OUCH - No wonder it looks so good. I would expect a nice briefcase to house it for that price LOL
    I must say I like the twin motor pairs. I had not seen that before.
    edited 2010-03-20 16:18
    This is one of the nicest frames I have seen, especially if you are mounting a camera. The motors are mounted on square carbon fiber rods but the under carraige is designed to balance a camera and battery to keep the center of gravity centered on the motors.
    http://www.nicoleto.com/NicoletoMK/Home.html
    edited 2010-03-20 16:28
    I think that the price is a bit high and I think also that kf4ixm is wrong. I think that probably you will end to around 5000 (material costs) then you have to take in account some incomes. And finally I hope that some good engineering has been put in the software and in the mechanical project (eg. I hope that if you make a wrong landing you doesn't destroy everything). But this is not my field.
    edited 2010-03-20 16:37
    The 9DOF just got here, let the testing begin. Attached is a picture for anyone that has not seen it before.
    Once we have an idea of weight we can start calculating motor size.
    www.graysonhobby.com/catalog/microjet-combo-microjet-p-765.html?affiliate_banner_id=1
    Here is a link to a site that I have purchased some motors and ESCs before. They also have a FAQ section that explains some basics of selection criteria. One thing to keep in mind is that not all props are easily available as pushers, we don't want to pick some off the wall sizes that we have to order from China.
    Cheers,
    John
    1493 x 1604 - 521K
    9DOF.jpg 521.1K
  • HannoHanno Posts: 1,130
    edited 2010-03-20 20:07
    John,
    Now the fun begins! I recommend using one of the gyro's to tell you if the craft is turning about it's axis- that's what everyone in the rc-helicopter world does. The gyro very accurately measures how quickly you turn about an axis- no matter the tilt or magnetic field. If you need a compass for navigation you might be able to low-pass filter (on the order of seconds) the compass signal to reduce tilt/noise from fields- but that won't help you with the very short-term corrections you'll need to keep it stabilized. Of course you could always kalman filter the gyro and accelerometer signals to get a steady signal that doesn't drift.
    Hanno
    Co-author of the official Propeller Guide- available at Amazon
    Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
    12Blocks, the block-based programming environment (thread here)
    and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
    edited 2010-03-20 20:23
    Most of the Quads/Hexa copters run 1000 to 1200 kv/rpm brushless outrunners.
    Most propellers are 8 to 10 inch diameter with a pitch of 4 or 4.5 inches.
    Of course you have to get push/pull propeller pairs:
    nghobbies sells these props in pairs 8,10 and 12 inch diameter with a pitch of 4.5 inches. These are used in the Mikrocopter
    Look here: http://www.nghobbies.com/cart/index.php?main_page=index&cPath=125
    Also some have mounted these motors upside down using special motor mounts. Not sure why this is done.
    edited 2010-03-20 21:58
    I tested the Parallax Ping))) Sensor using concrete as the reflective surface. The Sensor was tested at 10, 15, 24, 30, 40 ,60, 70, 80 inches with tilt of 0 to 40 degrees. The sensor was accurate at all heights from 0 to 30 degrees. At 35 degrees of tilt the distance measured was not always accurate.
    I couldn't attach an Excel spreadsheet so I converted to text file. The column headings don't line up but the first column is the height of the ping sensor measured with a ruler. The second column is the height as measured by the PING))) sensor and the third column was the angle in which the sensor was tilted.
    edited 2010-03-20 22:01
    Here are a few pictures of my apparatus for testing different sensors.
    600 x 900 - 111K
    600 x 900 - 110K
    600 x 900 - 81K
    edited 2010-03-20 22:41
    Sale costs have to include production costs AND development costs. After spending over an a hour on the site and viewing the videos, this company, it is my opinion, has spent many thousands of dollars to produce this quality product that is worthy of the cost. Let's not pollute this thread with debate on a subject that's not directly related to Ray's original post.. We could take it to the Sandbox to discuss further.
    kf4ixm said...
    @dMajo
    Sorry, while i respect your right to disagree with me, your comment saying that i am wrong without proving that im wrong it is just plain rude. sure there's some cost involved, but buying parts in bulk as most companies do, i still say theres not that much cost in the production.
    dMajo said...
    edited 2010-03-20 22:45
    Cluso, I would tend to keep the airframe and the circuit boards as separate entities, possibly with flexible mounts between, it is easy enough to make various plates etc from epoxy glass or carbon fibre to a high quality even with hand tools.
    Graham
