My small spaces inspectgion robot
I just wanted to share a robot I made to inspect comercial "cookie and crackers" ovens. the robot will be used to inspect the walls and burners inside a 250' long oven, it needs to no taller than 3-3/4" so it can pass under the burners that are located each 4 feet apart. I implemented one of my R/C pan/tilt camera mounts modified for this uniden wireless camera, there are smaller cameras outthere but this one has great night vision and great resolution, plus the video feed is private been 2.4ghz FHSS.
I'm using parallax servos on the tires and normal futaba servos on the pan/tilt assembly, I laser cut the chassis using 1/8" mdf
Enjoy
http://www.youtube.com/watch?v=Z1T9PaOSPYw
Enjoy
That came out really nice! I looks great too. Thanks for posting your video.
Whit+
Signature space for rent!
Send $1 to CannibalRobotics.com.
I've never used MDF before; but, since I have a laser cutter, I'm interested in its properties. How strong is it compared with an equal thickness of plywood? Do the edges laser clean, or does the material flake off?
You don't want to let it get wet.
Think "particle board" but made from sawdust, not particles.
Is it stronger? Questionable. I'd have to look up the actual strengths, but my "anecdotal" reply would be “depends”. Within its limits, it is more rigid, but beyond the limits, it breaks, it doesn’t bend. It can also tend to split (analogous to plywood delaminating) when you try and flex it beyond it’s limits.
John R.
Click here to see my Nomad Build Log
Now getting a robot to thread a wire or cable through a hole in the floor will be a good trick. Might need a few extra RELAYS for that kind of precision. [noparse]:)[/noparse]
YEA! You got that right! It also warps due to chages in humidity.
Awesome stuff for DIY though.
That little Bot come out nice! I like it.
"puff"...... Smile, there went another one.
http://www.youtube.com/watch?v=gKDVfr-t99c
http://www.gowiththeshark.com/
If you haven't seen a video of it in action, just youtube FPV r/c planes
I noticed in the latest picture that the MDF seems thinner than anything I've seen around these parts (Wisconsin). Did you plane that down, or is MDF available where you that thin?
About the only thing we can get that thin around here is maybe plywood at the "right place", or masonite.
John R.
Here is a video of one of the pods I make for the easy star airplane.
http://www.youtube.com/watch?v=4_gqHNWXRIM
here is a video of the bigger version of the pan/tilt, I updated the design also the new design is implemented on the robot I just did.
http://www.youtube.com/watch?v=0hESe5YHeUQ
Post Edited (cdesigns) : 3/19/2010 7:20:44 PM GMT
