My small spaces inspectgion robot — Parallax Forums
cdesignscdesigns Posts: 13
edited 2010-03-20 02:16 in Robotics
I just wanted to share a robot I made to inspect comercial "cookie and crackers" ovens. the robot will be used to inspect the walls and burners inside a 250' long oven, it needs to no taller than 3-3/4" so it can pass under the burners that are located each 4 feet apart. I implemented one of my R/C pan/tilt camera mounts modified for this uniden wireless camera, there are smaller cameras outthere but this one has great night vision and great resolution, plus the video feed is private been 2.4ghz FHSS.
I'm using parallax servos on the tires and normal futaba servos on the pan/tilt assembly, I laser cut the chassis using 1/8" mdf
Enjoy
http://www.youtube.com/watch?v=Z1T9PaOSPYw
  • WhitWhit Posts: 4,191
    edited 2010-03-14 17:30
    cdesigns,
    That came out really nice! I looks great too. Thanks for posting your video.
    Whit+
    edited 2010-03-14 23:02
    That's neat.
  • agfaagfa Posts: 295
    edited 2010-03-15 11:53
    Good job on the bot.· Thanks for posting.
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-03-15 21:31
    nice!
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
    edited 2010-03-15 21:53
    That's a very nicely done 'bot you have there!
    I've never used MDF before; but, since I have a laser cutter, I'm interested in its properties. How strong is it compared with an equal thickness of plywood? Do the edges laser clean, or does the material flake off?
  • John R.John R. Posts: 1,376
    edited 2010-03-15 22:15
    MDF is denser than plywood, but doesn't have any grain. It doesn't flex as much as plywood, and I guess I would call it relatively brittle. It also doesn't warp, and is more stable than plywood, both in terms of staying flat, and dimensionally.
    You don't want to let it get wet.
    Think "particle board" but made from sawdust, not particles.
    Is it stronger? Questionable. I'd have to look up the actual strengths, but my "anecdotal" reply would be “depends”. Within its limits, it is more rigid, but beyond the limits, it breaks, it doesn’t bend. It can also tend to split (analogous to plywood delaminating) when you try and flex it beyond it’s limits.
    John R.
    Click here to see my Nomad Build Log
  • cdesignscdesigns Posts: 13
    edited 2010-03-16 06:20
    The MDF cuts very nicelly, the MDF I use is very solid,·the laser cuts 1/16" holes very clean and tight, the plywood tends to burn more on the edges,·the quality of the MDF I use is good for small projects and it holds up abuse. you can wet this MDF and it will not come apart unless you beat the heck out·of it, and when it dries it keeps it shape, it doesn't sponge. ·I use the mdf for all my laser cut R/C pan/tilts and camera mounts, is cheaper for me and for my customers, compared to high grade hobby plywood.
    Phil Pilgrim (PhiPi) said...
    edited 2010-03-16 18:19
    Makes me think about a robot to inspect & pull wires under my house. That crawl space is no fun! Make a robot that fits through a removeable vent cover and let it do the dirty work...
    Now getting a robot to thread a wire or cable through a hole in the floor will be a good trick. Might need a few extra RELAYS for that kind of precision. [noparse]:)[/noparse]
    edited 2010-03-16 22:03
    John R. said...
    ....... You don't want to let it get wet.........
    YEA! You got that right! It also warps due to chages in humidity.
    Awesome stuff for DIY though.
    That little Bot come out nice! I like it.
    "puff"...... Smile, there went another one.
    edited 2010-03-19 14:00
    Here is the last version, with a guard so the wheels doesn't felt on the oven corners.
    http://www.youtube.com/watch?v=gKDVfr-t99c
  • DesslokDesslok Posts: 22
    edited 2010-03-19 18:45
    That is really cool. Can you imagin this paired with an R/C FPV system? That would be really cool.· I always wanted to get one of these for my planes:
    http://www.gowiththeshark.com/
    If you haven't seen a video of it in action, just youtube FPV r/c planes
    edited 2010-03-19 18:57
    CD:
    I noticed in the latest picture that the MDF seems thinner than anything I've seen around these parts (Wisconsin). Did you plane that down, or is MDF available where you that thin?
    About the only thing we can get that thin around here is maybe plywood at the "right place", or masonite.
    John R.
    edited 2010-03-19 19:14
    I make Pan/Tilts for RC Airplanes, and I have a universal mount for mini spy cameras.
    Here is a video of one of the pods I make for the easy star airplane.
    http://www.youtube.com/watch?v=4_gqHNWXRIM
    here is a video of the bigger version of the pan/tilt, I updated the design also the new design is implemented on the robot I just did.
    http://www.youtube.com/watch?v=0hESe5YHeUQ
    Desslok said...
    Post Edited (cdesigns) : 3/19/2010 7:20:44 PM GMT
    edited 2010-03-19 19:17
    I founf this MDF at a local wood supplier, is 1/8" thick and very tight compressed. I need to buy more for some projects I will get you the information on where to buy it. all I can say is that the cost is dirt cheap $8 for a 8'x4' panel.
    John R. said...
    CD:
    cdesigns said...
    [noparse][[/noparse]color=#990000>
    Wow, so cool. Hopefully I can learn to make my own some day. A friend of mine has an Easy Star, great plane. I have a 25 and a 40 size trainer that would be good for a camera as well.
    Desslok said...
    That is really cool. Can you imagin this paired with an R/C FPV system? That would be really cool. I always wanted to get one of these for my planes:
