Bent pin on BS2
I have a BS2 that the Vin pin is bent. I believe that it got bent when I installed it into a breadboard. It's in pretty bad shape and I'm not able to straiten it out to get it to work again.
Has anyone been able to repair one? Can you solder a new pin in place and if you can, where can you purchase a replacement pin?
I can solder normal thru hole parts but I am unsure of my ability to solder to the BS2. The parts are very small on there......
Does Parallax offer repair for them? What am I looking at for a repair cost if they can repair them?
Nick
Nick
Always be careful when installing into breadboards.
Tom Sisk
http://www.siskconsult.com
Good point, Tom. I forgot about that pin.
Nick
Open the Parallax box with your new BASIC STAMP!!! and before doing anything, find a socket to mount it to so you don't damage the pins.
I didn't listen (cause I didn't have a socket on hand) and in the excitement to use my new toy, boogered the pins all up. I was lucky. Now it's mounted in a 24 pin IC socket... so every 20th time I plug the stamp in someting it bends the pins on the socket, not the stamp. The socket's pins are stronger than the stamp anyways.
DigiKey and Mouser have wire wrap sockets that work great in a breadboard.
"puff"...... Smile, there went another one.
Nick
.....and they weren't long enough to plug in. stupid.stupid.stupid.
Good information reading this post.
"When the government is afraid of the people there is liberty, when the people are afraid of the government, there is tryanny"
· Thomas Jefferson
