Make my own "Hydra" ???
WBA Consulting
I am thinking of making a pocket version of the Hydra that fits in a small box kind of like those joysticks that have video out and are loaded with some retro games like frogger. Are there any issues with doing this? I know that some of the Hydra support files are only available on the Hydra CD when you buy the kit, but since I have that, I can use them on something other than a Hydra, correct? I won't be making it as a setup to sell, but if I did, what concerns should I have over issues with Hydra copyright/trademark/etc? I guess what I am asking is what is stopping anyone from selling a Propeller game setup that is basically the same as the Hydra and plays games designed for the Hydra?
Andrew Williams
WBA Consulting
Special Olympics Polar Bear Plunge, Mar 20, 2010
Andrew Williams
WBA Consulting
OBC
New to the Propeller?
Andrew Williams
WBA Consulting
I was thinking around the same lines however I have not come up with a great idea for it.
I wanted it to be portable and I was thinking on building it somewhat compact like the new
EL Jugador: www.gadgetgangster.com/find-a-project/56?projectnum=265
Post Edited (Rob7) : 3/22/2010 2:14:39 PM GMT
Andrew Williams
WBA Consulting
1) Anyone have experience making their own NES controller circuit? I picked up 4 of the CD4021 chips today at HFE and will be connecting one with the Parallax 5 position switch and a few pushbuttons. Anything I should look out for is it as simple as it looks?
2) Phase 2 will involve adding an SD card with bootloader to pick a game. I'll be picking apart some game code to determine how to use the joystick to navigate through a menu since I will be without a keyboard. Comments?
3) I am using the 2.5" display from NiteMax Mark, but I would really like to change to a larger one when I find one that doesn't have an enormous driver board. Brilldea's 3" display looks nice, but is out of stock. I have a 5" display from a PSOne LCD pack, but the driver board is about an inch too wide to fit in the case I am using. I am locked on the case because it is large enough for all the required hardware yet small enough for handheld comfort. I just wish I could find a larger composite video screen that would fit in it.....
I didn't realize how simple and clean the Hydra layout is until I spent all this time digesting the schematic. I will definitely be giving Andre' some praise in my completed projects post when I complete this. I have had a lot of questions about the Hydra from time to time, but with all the time I have recently spent with Hydra book and schematic, I know it well. I just need to get my SPIN down better so I can take advantage of this new understanding.
Andrew Williams
WBA Consulting
