Make my own "Hydra" ??? — Parallax Forums
WBA ConsultingWBA Consulting Posts: 2,938
edited 2010-03-28 08:35 in Propeller 1
I am thinking of making a pocket version of the Hydra that fits in a small box kind of like those joysticks that have video out and are loaded with some retro games like frogger. Are there any issues with doing this? I know that some of the Hydra support files are only available on the Hydra CD when you buy the kit, but since I have that, I can use them on something other than a Hydra, correct? I won't be making it as a setup to sell, but if I did, what concerns should I have over issues with Hydra copyright/trademark/etc? I guess what I am asking is what is stopping anyone from selling a Propeller game setup that is basically the same as the Hydra and plays games designed for the Hydra?
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
    edited 2010-03-08 14:20
    The issue might be centered more around the distribution of the games themselves in a commercial package than in creating a clone. While the Game Stacker and El Jugadorare not identical clones to the Hydra, but contain the Propeller as the core and hence are compatible with the games.
    OBC
    New to the Propeller?
    edited 2010-03-09 01:20
    Sounds reasonable. I don't plan on distributing any games, just making a smaller, more basic, more durable, "hydra style" system for my daughter while publishing the details for other do-it-yourselfer's. Others would have to download the games themselves as I would only be setting it up with an SD "game list" bootloader.
    Andrew Williams
    WBA Consulting
  • Rob7Rob7 Posts: 275
    edited 2010-03-22 14:09
    Hi Andrew,
    I was thinking around the same lines however I have not come up with a great idea for it.
    I wanted it to be portable and I was thinking on building it somewhat compact like the new
    EL Jugador: www.gadgetgangster.com/find-a-project/56?projectnum=265
    Post Edited (Rob7) : 3/22/2010 2:14:39 PM GMT
    edited 2010-03-22 16:08
    I was looking to make mine portable as well. I am planning on putting a Gadget Gangster Propeller Platform board in a case and use a small protoboard for the video out and controller circuits for my prototype. It will use the 2.5" display from NiteMax Mark and an energizer 12 volt Li-ION pack. The controller will be scratch built and will probably just use small tact switches.
    Andrew Williams
    WBA Consulting
    edited 2010-03-22 18:09
    Very interesting !
    Just an update and a few thoughts since I know a few people are following my progress (I have received several PMs on this project). I have everything I need now to finish off my setup for my portable propeller gamer. I am not calling it a portable Hydra, because it will lack many things that are found on the Hydra. It will simply be a handheld device that is pinned for games designed for the Hydra. I finished my notes for all of the connections tonight and will begin wiring things up tomorrow. A few thoughts:
    1) Anyone have experience making their own NES controller circuit? I picked up 4 of the CD4021 chips today at HFE and will be connecting one with the Parallax 5 position switch and a few pushbuttons. Anything I should look out for is it as simple as it looks?
    2) Phase 2 will involve adding an SD card with bootloader to pick a game. I'll be picking apart some game code to determine how to use the joystick to navigate through a menu since I will be without a keyboard. Comments?
    3) I am using the 2.5" display from NiteMax Mark, but I would really like to change to a larger one when I find one that doesn't have an enormous driver board. Brilldea's 3" display looks nice, but is out of stock. I have a 5" display from a PSOne LCD pack, but the driver board is about an inch too wide to fit in the case I am using. I am locked on the case because it is large enough for all the required hardware yet small enough for handheld comfort. I just wish I could find a larger composite video screen that would fit in it.....
    I didn't realize how simple and clean the Hydra layout is until I spent all this time digesting the schematic. I will definitely be giving Andre' some praise in my completed projects post when I complete this. I have had a lot of questions about the Hydra from time to time, but with all the time I have recently spent with Hydra book and schematic, I know it well. I just need to get my SPIN down better so I can take advantage of this new understanding.
    Andrew Williams
    WBA Consulting
