LCD Bargraph help
This code dispays RPM and a percentage of how fast your going with a bar graph. How can i make this code so that the bar graph displays on a 4 x 20 LCD screen instead of a 2 X 16. So the bar graph doesn't stop at the 16th position and keeps going till the 20th.
' {$STAMP BS2} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] I/O Pins ]----------------------------------------------------------- LcdPin PIN 15 SpeedIn PIN 3 ' -----[noparse][[/noparse] Constants ]---------------------------------------------------------- T9600 CON 84 ' True, 8-bits, no parity, 9600 Capture CON 5000 LcdCls CON 12 ' Form feed -> clear screen LcdCr CON 13 ' Carriage return LcdOff CON 21 ' Turns display off LcdOn CON 22 ' Turns display on Line0 CON 128 ' Line 0, character 0 Line1 CON 148 ' Line 1, character 0 Define CON 248 ' Address defines cust char 0 LcdBLon CON $11 ' Backlight On ' -----[noparse][[/noparse] Variables ]---------------------------------------------------------- rpm VAR Word pulses VAR Word custChar VAR Nib ' Custom charcter selector index VAR Nib ' Eeprom index variable dotLine VAR Byte ' 5-pixel dotted line cursor VAR Nib ' Cursor placement value VAR Byte ' Value to be graphed. charCnt VAR Byte ' Character counting variable line VAR Byte ' Line0 or Line1 percent VAR Byte highVal VAR Word ' -----[noparse][[/noparse] Initialization ]----------------------------------------------------- PAUSE 100 SEROUT LcdPin, T9600, [noparse][[/noparse]LcdOn, LcdCls, LcdBLon] PAUSE 5 custChar = 3 dotLine = %11111 GOSUB Def_Horiz_Bar_Char line = Line1 pulses = 0 highVal = 3500 DO GOSUB Acquire_RPM value = rpm / 44 GOSUB Bar_Graph: LOOP Acquire_RPM: COUNT SpeedIn, Capture, Pulses rpm = (pulses * 12) percent = (rpm / (highVal / 100)) RETURN Bar_Graph: value = value MAX 80 charCnt = value / 5 custChar = 3 IF charCnt > 0 THEN FOR cursor = 0 TO charCnt - 1 GOSUB Disp_Cust_Char NEXT ENDIF cursor = charCnt custChar = value // 5 LOOKUP custChar, [noparse][[/noparse]%00000, %10000, %11000, %11100, %11110], dotLine custChar = 2 GOSUB Def_Horiz_Bar_Char GOSUB Disp_Cust_Char IF (charCnt + 1) < 15 THEN FOR cursor = (charCnt + 1) TO 15 SEROUT LcdPin, T9600, [noparse][[/noparse]line + cursor, " "] NEXT ELSEIF value = 80 THEN SEROUT LcdPin, T9600, [noparse][[/noparse]line + cursor, 3] ELSEIF charCnt = 14 THEN SEROUT LcdPin, T9600, [noparse][[/noparse]line + 15, " "] ENDIF RETURN Def_Horiz_Bar_Char: SEROUT LcdPin, T9600, [noparse][[/noparse]Define + custChar] FOR index = 0 TO 7 SEROUT LcdPin, T9600, [noparse][[/noparse]dotLine] NEXT SEROUT LcdPin, T9600, [noparse][[/noparse]134, DEC rpm, " RPM "] SEROUT LcdPin, T9600, [noparse][[/noparse]164, DEC percent, "% "] RETURN Disp_Cust_Char: SEROUT LcdPin, T9600, [noparse][[/noparse]line + cursor, custChar] RETURN
Also there will be changes in the program segment that begins with
where numbers 15, 80 and 14 should probably(?!) be 19, 100 and 18, respectively.
Tracy Allen
www.emesystems.com
